Looking for some design drawings for a root rake
   / Looking for some design drawings for a root rake #1
Cord
Richfield, Wi
Resident Architect
   / Looking for some design drawings for a root rake #2
Cord,
I don't know if you are still interested but I do have a cad file for the root grapple. Sorry, I took so long to respond. I've had some other things going and just have not had the time to logon for a while. Let me know if you are still interested.
jba
Yes, I would be interested. Just send it to einwaltert at yahoo.com
   / Looking for some design drawings for a root rake #4
Cord -
How big is your tractor, and do you plan on using a quick attach plate? If you have limited lift or breakout capacity, you definitely want to watch the weight.
After a year of procrastination, I finally built my rake/grapple this fall for my Kubota L2800, and it has worked out very well so far, but it is pretty light weight (about 250 lbs. without the cylinder). I saved weight by unpinning the bucket and pinning on the rake without using a QA plate. It's a little more pain changing it, but definitely worth it in performance.
Just a thought.
Regards,
- Just Gary
P.S. I also really like jba's rake design.
It'll be going on my loader. If I recall correctly, it has around 5,000lb of breakout force. Quick attach, but it doesn't use the standard skidsteer plate.
   / Looking for some design drawings for a root rake #6
Cord -
That's probably four times the force available with my L2800, so the extra weight is not going to hurt you.
Building up the two boxes to fit my loader's arms took as long as the rest of the grapple, since they had to closely match the existing parts (and had four bushings each).
Did jba get you fixed up with the QA plate mounting parts also, or just the rake?
Keep us posted on your build!
Regards,
- Just Gary
   / Looking for some design drawings for a root rake #7
Cord,
jba
Would you also share your root grapple file with me, if so I would really appreciate it.
My email is craigdavis.com@gmailcom
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
