Looking for lights for my tractor
/ Looking for lights for my tractor
Thanks Captain....I have a wonderful wife who is completely dedicated to her children and her husband,and that helps a lot.
I am fortunate.....and I am dedicated as well./w3tcompact/icons/smile.gif
/ Looking for lights for my tractor #22
<font color=blue>"I also made a jumper cord that is cig on one end, and battery clamps on the other"</font color=blue>
Are cigarette lighter sockets heavy enough for jump starting a vehicle? What gauge wiring is run to the lighter socket?
/ Looking for lights for my tractor #23
<font color=blue>"Are cigarette lighter sockets heavy enough for jump starting a vehicle?"</font color=blue>
No. You can trickle charge with a cigarette lighter plug but it will never hold up to the amps needed for a jump start.
/ Looking for lights for my tractor #24
OK, that's what I'd always thought. Thanks. /w3tcompact/icons/smile.gif
/ Looking for lights for my tractor #25
Depends on what you are doing. For jumping off my riding lawnmower ( purpose for which it was designed ), it works great.
Soundguy
<font color=red>Are cigarette lighter sockets heavy enough for jump starting a vehicle? What gauge wiring is run to the lighter socket?
/ Looking for lights for my tractor #26
My cig lighter outlet is run on 8 gauge wire. I made the jumper to go to my riding lawnmower. The jumper wire itself is probably 10 gauge, and is roughly the same size as the battery cables on the rider. Usually it just needs an 'assist', or boost... Depends if i have left its lights on, or was using it to run a tire pump etc.
Many companies make an 'assist' cable for lighter to lighter connections, as well as booster boxes that connect to the lighter. In most cases though, you have to realize that there is only a 20 - 25 amp fuse on that circuit.. and that is the limit of the assist you can get by with without a fuse failure. If your lucky, it is on a breaker like a power window, etc.
Soundguy
red]Are cigarette lighter sockets heavy enough for jump starting a vehicle?"
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
2015 Doosan 750CFM T/A Towable Air Compressor (A59228)
2015 Doosan 750CFM...
UNKNOWN 500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
