Looking for DIY Subsoiler to install direct burial 4/0,4/0,2/0,4 URD
   / Looking for DIY Subsoiler to install direct burial 4/0,4/0,2/0,4 URD #11
Won't happen. That cable needs 24" of cover and you don't have the HP to dig that deep. I'd suggest a chain trencher if the soil is clear or a mini excavator if it's rocky.
Also, because this is a sub panel, I believe you need the neutral to be the same size as the conductors. Don't forget to include a disconnect in the building.
I agree with using a trencher or backhoe/excavator for this project. I would not try to save money on the trench at the expense of possibly damaging the wiring. Two hundred feet is a long way to pull the wires through the ground and doubt you can do it without some damage. This damage might not show up for a couple of years but reworking will cost even more money.
If you want to pull something through the ground that far leave it to cheap pipe not expensive feeder cable.
   / Looking for DIY Subsoiler to install direct burial 4/0,4/0,2/0,4 URD #12
on a project like this you do not pull the wires in, you, feed the wires in, the difference is the machine is similar but one pull an done has a tube that guides the wire or what ever in the bottom of the cut trench,
Astec RT1160 Cable Plow Demo - YouTube
   / Looking for DIY Subsoiler to install direct burial 4/0,4/0,2/0,4 URD #14
Kenny d's also was designed to feed the cable rather than pull it.
CASE TV370B SKID STEER (A51242)
CASE TV370B SKID...
Quick Attach Accumulator Grapple (A50514)
Quick Attach...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51243)
UNUSED X-STAR 101"...
2013 F-550 Bucket Truck (A52128)
2013 F-550 Bucket...
(INOP) CATERPILLAR 259D SKID STEER (A50459)
(INOP) CATERPILLAR...
71065 (A49346)
71065 (A49346)
