jenkinsph
Super Star Member
Won't happen. That cable needs 24" of cover and you don't have the HP to dig that deep. I'd suggest a chain trencher if the soil is clear or a mini excavator if it's rocky.
Also, because this is a sub panel, I believe you need the neutral to be the same size as the conductors. Don't forget to include a disconnect in the building.
I agree with using a trencher or backhoe/excavator for this project. I would not try to save money on the trench at the expense of possibly damaging the wiring. Two hundred feet is a long way to pull the wires through the ground and doubt you can do it without some damage. This damage might not show up for a couple of years but reworking will cost even more money.
If you want to pull something through the ground that far leave it to cheap pipe not expensive feeder cable.
