Looking for Discontinued gasket
   / Looking for Discontinued gasket #1
tcartwri
Elite Member
Ontario
CT235
Long time no post... I'm in a bind.
I'm looking for a cross reference for Bobcat PN# 6697252, Gasket, for the hydrostatic assembly.
It goes between the Front Cover casting and the pump body.
Bobcat CT235 SN# A9JY11001 & above.
Hopefully Kioti still carries the part, but I don't have a parts manual for them.
Thanks.
This is the part in question. You can see the deformity in two places. I don't know how it ever not leaked.
   / Looking for Discontinued gasket #6
might research Permatex Grey. Have used it for years. Has more holding ability than most. Always used on rear axle covers. No leaks.... a bit tough to take apart though :)
   / Looking for Discontinued gasket #7
I found this. 41
GASKET
GASKET,NLA - Was 6697252 you can buy gasket material and cut your own, or use Permatex® OPTIMUM RED Gasket Maker
Ya, I would be hesitant to put that in a pump body..... The gasket also sets the clearance on the pump faces.
Bobcat NY has access to the part apparently. Will be ordering on Monday.
   / Looking for Discontinued gasket #9
Interesting how the gasket got sucked in and cracked. Must be low pressure/vaccum in that area.
Curious what symptoms you had to direct you to this gasket. Did you have a lot of air introduced into the hydraulic fluid?
It's been like this since day one. ( the tractor is a 2011 )
You can see the witness marks on the gasket where it was clamped out of shape between the castings.
It started as a slow drip that I noticed in early summer and by the time I got my hay in the barn it was pissing fluid everywhere. No loss of performance to either the hydrostatic or the hydraulics.
(INOPERABLE) GEHL 8K TELEHANDLER (A58216)
(INOPERABLE) GEHL...
UNUSED FUTURE DHC 60" PALLET FORKS (A58376)
UNUSED FUTURE DHC...
DODGE LONG WHEEL BASE TRUCK BED (A58376)
DODGE LONG WHEEL...
UNUSED SDLANCH IRET13 ELECTRIC TRICYCLE (A58375)
UNUSED SDLANCH...
20' 24" Metal Corrugated Pipe (A57149)
20' 24" Metal...
2000 Caterpillar 3412 500kW 3-Phase Diesel Generator (A56857)
2000 Caterpillar...
