looking for brand recomendation
/ looking for brand recomendation #21
Well if you have 4 to 5-grand to play with, here you go! :laughing:
AH I see you got a LF-72 now. Did the LN-25 not work very well with the invertec?
/ looking for brand recomendation #22
No the LN-25 works perfect, just got a good deal on the LF-72! $1,000.00 + for the feeder, with over $850.00 in options, but I paid $650.00.
/ looking for brand recomendation #23
Wow very nice! What sort of gun does it have?
/ looking for brand recomendation #24
Didn't come with a gun, came with 100-feet of cable tho. My Tweco model 2 gun fits it, and the pigtail from the Tweco adapter to the LN-25 works on it as well. It came with a set of 1/16th inch serrated drive rolls. I ordered .023/.030, .035/.045 V-groove drive rolls for it. Tomorrow I'll go back to the welding supply and see which bushing kit I need so my Lincoln K-126 Innershield gun will work with it too. Then I might order some smaller serrated drive rolls for it.
/ looking for brand recomendation #26
Umm,
Yomax,
Our MTS 160 and 200S is a good competitor to your 3n1, and we had it in the US a year before yours.lol...
Look familiar? Not so unique as TA makes out!
I like it. hows it doing? Should be a hot item..
/ looking for brand recomendation #27
Yomax4 do you know anything about those ESAB caddy migs?
Caddy's are ( I hear ) from Poland. They have everything in Metric. So your wire speed in millimeters instead on inches. Don't care for the little toy guns but they aseem to be selling ok.
/ looking for brand recomendation #28
Doing well so far. Slow out the gate but picking up rapidly.:thumbsup:
/ looking for brand recomendation #29
Where did you get that?
MTS 160 160 amps@ 30% duty 799.00
ThermalArc 181 180 amps@ 20% duty 999.00
MTS 200 Synergic operation MIG 200 amps @25% duty 999.00
Both MTS, have built in gas solenoid valve for TIG operation. TA does not and you have to manually control gas operation. Also we use a Euro quick connect...which is easily connected. No spool gun needed. Wire will feed through gun on mts and has aluminum setting on MIG on MTS 200.
On the plus side for the TA, you have a foot pedal (which is of limited value on a DC lift start tig)...
Wondering why a foot control would be of limited use on a lift start Tig. Foot controls do more than start the arc. Anyway. It's off to a 3 million dollar in 3 month launch. Must be something ok about it..
/ looking for brand recomendation #31
Hello, I'm new to this thread. If I may offer my oppinion. It's red or blue. I personally own a miller 211 with auto set. Has what they call an MVP. Multi voltage plug. 110 or 220. Has a spool gun as an option to weld alum. Will last a homeowner a lifetime. @1200$ new
Good choice if you only need 180 amps. Spool gun is marginal but will do in a pinch. Ok machine.
/ looking for brand recomendation #32
Sorry about that, I didnt know you changed the prices. When I last looked, the mts 160 was around $1200. Also, I am sure if you put a teflon liner on the thermal arc, you could do aluminum without a spool gun. Someone on here was doing that with a standard liner and a hobart handler 140. I guess I will have to take another look at the everlast before I decide on a welder.
