Eagle1
Veteran Member
- Joined
- Jul 4, 2003
- Messages
- 2,370
- Location
- Viburnum, MO
- Tractor
- Kubota BX2200, LS XG3135H, Grasshopper and Yazoo Zturns
The Dexters will eliminate all the woody growth down low and trim all your trees as high as they can reach. I started with overgrown ground they are are turning into grass land. Currently rotation is not a good solution but once I close up here they will gain a ton of pasture in the bottom of the holler and I won't be cutting grass every 5 days.
Hay is always a challenge in dry years it helps to have someone you do you long term business with, well until they change the rules mid stream. I finally found someone close that was expanding and I hope to do business with him long term. Most of the hay around here has a home before it is cut.
I have learned that cows you know well are good for the soul, it's peaceful to sit in the pasture and watch them feed, with most friendly coming up for a good scratch.
