Looking for a tractor
/ Looking for a tractor #1
darius
Kansas City
Deere 318
This board has been a great help in my year long search for a CUT. I haven't taken the leap yet, but think I should get your input since we have moved and are in a little dirrerent situation.
We are on 5 acres, mostly wooded with about 1.5 acres to mow, LOTS of trees.
My intended uses are: Mowing, pulling the aereator, the spreader and the roller, moving firewood, pushing snow and maintaining 350 feet gravel drive. Also looking at several lanscaping projects including rock and retaining walls. Gardening and clearing some of the woods for a trail.
Lawn is flat to gentle rolling. Woods are steep and rocky but have a good path.
I was thinking about getting a ZTR commercial walk behind to mow with and then getting an older CUT (Kubota 7100,7200 or Ford 1210) for the other work.
But now I'm wondering if a single unit with power steering and a belly mower would do the jab and be better (Like a BX, or Kubota 2100, 1700, 1750)
I would like to get a loader eventually, but am willing to start out with a dirt scoop and box blade.
Really don't want to spend over teh $6000 mark and don't want a project tractor.
Currently use a Deere 318 with a front blade and Cat 0 3 pt.
Can anyone help me focus my thinking from the 2 unit option or the single unit option?
I appreceiate all the help.
/ Looking for a tractor #2
Unless the 318 is on it's last legs or you're just plain tired of it for some reason it will take care of your lawn chores without a problem. Put a snow blower on the front and use the skid shoes to keep it off the gravel and your drive will stay clear. When you want to get started on the landscaping projects you should look into a used CUT with a loader for the woods clearing and rock/soil hauling. Consider a Hydro trans for the loader work and it will go a lot quicker and easier. With the woods being hilly you will want to pay close attention to the outside track width of the tires. Wider usualy = safer on hills but the key is center of gravity and if you do a search on this site for that topic you will find lots of info. I think your money will go farther if you stick to a L&G tractor for the yard chores rather than investing in a single use ZT whatever. By buying a used CUT you will be able to get a bigger machine for the money than you would buying new.
/ Looking for a tractor #4
<font color=blue>Really don't want to spend over teh $6000 mark and don't want a project tractor</font color=blue>
Tough call for your price range. Are you sure you don't want to add a 1 in front of the $6,000 to make $16,000?/w3tcompact/icons/wink.gif Lots of options for financing. Sometimes you just got to bite the bullet and go for it. You only live once. (Gee real easy for us to spend your money.
I think I've got some relevant experience to answer your question.
I have 4 acres, 2 to mow, the rest trees. Front half is rather steep, back half pretty flat. In high school & college I worked summers mowing lawns with commercial walk behinds 36" to 54".
Without a doubt, the walk behind mower will mow faster than a CUT. Cut quality will be somewhat better, but I've been very impressed with My New Holland MMM, also had a Rear Landpride that cut well, and Everybody seems to love the 60" deck on the BX.
A used walk behind in good shape will cost about what a rear finish mower will ($1,200+/-) so strickly speaking cash, it's a wash. A mid mount mower costs what a new walk behind mower costs ($2,000 - $2,500). Plenty of reading on Rear vs Mid Mount here, do a search (I prefer the MMM).
So do you have space for two machines? Do you want to maintain two machines? Why not keep your 318? Or is it time to put it out to pasture? One of my "selling points" to get the wife's approval was that the CUT would do it all! The ultimate power tool.
Not a very educated guess here, but I don't know if you'll be able to find a modern CUT with hydro for $5K (this is assuming you spend $1K on the walk behind mower)
I think it is time for you to pound the pavement and test drive some machines. Then you'll get a better feel if you want a sub-compact (BX) or Small compact (B7500 etc). Check out Deere & New Holland as well.
I've been very happy with my choice of the New Holland TC18. Cost $15,600 for Tractor, Loader, MMM, and rear blade.
PS Get the loader if you can at all afford it.
/ Looking for a tractor #5
Power steering really should be consider for fel & rear mower..the B7100 working little mule,but it will work you also.You might be in luck if you attend farm & dealer auctions..have you consider a nice 2wd tractor,for one could get a heck of a good deal for 6 grand. /w3tcompact/icons/wink.gif
/ Looking for a tractor #6
Power steering is a big plus.
I had a 245DT Kubota that I broke the steering box out of. It had a fel on it and all the presure was ultimately put on that little box. When I wore the tires out, I did the unthinkable thing and put a set of mud and snow tires for a pickup on. They were the same height so didn't effect the ratios. I found that the tires held up better and the steering was much easier. Of course the trade off was less traction up front, but only in soft ground. Other than that, I would certainly do it again.
/ Looking for a tractor #7
IMO: if your thinking small tractor for loader work I don't you gonna get by to well without 4x4.
/ Looking for a tractor #8
<A target="_blank" HREF=http://www.power-trac.com>Power Trac </A> has their 22hp 4wd hydraulically articulated tractor on sale for $6000.00. It comes with built in loader lift arms. A 10 cubic foot bucket is about $400.00. A 4' front mounted mower is about $900.00. All together, there are about 30 attachments available. You might want to check them out, just for the fun of looking /w3tcompact/icons/smile.gif
/ Looking for a tractor #9
$6000 is plenty
I will play devils advocate here - you can do plenty of work with $6000, but you have to make sacrifices. Here would be my solution: Either keep the 318 for primary mowing or sell it to buy another used ZTR/lawn tractor with hydro. This keeps your 6 grand for the real tractor, with the following general options:
Ford 1500, 1700, 1900 series circ 1980s. For 6k you might find a loader, definately can get 4wd. Usually a used unit will come with a brush hog, or box blade which you will need.
Kubota 6100, 6200, 7100, 8200 - the 6xxx series are a little small, but still useful if 4wd. A 7100 4wd with a few implements will fit this price range.
Grey Market (preferably Yanmar) 2000 series with loader can be had for 6k, possibly with another implement. Parts are readily available, but you should find a mechanic/dealer willing to do repairs before committing.
New Chinese tractors (Jinma, Deadong sp?)You can get a new chinese tractor for 6k, probably with few implements, no loader. Research would be required to make sure you are comfortable with this 'most risky' route.
I currently have 40 acres that I semi manage with cheap tractors. I had a little kubota b6000 with a bunch of implements, and now I am shopping in the $4-5,000 range. Top on my list is a very clean Ford 1700 2wd, a Mitsubishi 160d 4wd, and a few B7100s.
Dont get discouraged, and please visit jplan.com - there are nice folks with smaller wallets on that forum :)
/ Looking for a tractor #10
Re: $6000 is plenty
Steve, In this area, all you will find in that price range in a CUT will be junk! I sold my B8200 with FEL for $12k. and most tractors of that size will sell for over $10k If I could find them in the $6k range I would be buying them up and reselling them like hotcakes! I guess CUT sales are like real estate, location, location, location!!
/ Looking for a tractor #11
Re: $6000 is plenty
I'll second what Von said! Here in the southern tier of NY, $6000 won't buy much. Buying used was my original plan before I bought the BX, but I got so sick of looking at dented sheet metal and leaking hoses that I swallowed hard and bought the BX.
I remember looking at a B8200, FEL, MMM, that a dealer was going to give me a "good deal" on for $7500. I have never owned anything in such rough shape! He got his $7500, that was the scary part
/ Looking for a tractor #12
Darius, your profile says Kansas City area... you can get a quality used CUT in the $6000 range in the Heartland.. may or may not include an implement, mower etc.. You will have to look, take some time, research, there is, as pointed out alot of junk out there at high prices, but I can tell you from experience, there are good deals as well... $6000, will be pushing it for a 4WD...., certainly it can get a nice 2WD... you would probably want to make a final decision on whether you are ever going to want a FEL... If not, 2WD is fine for mowing either with a MMM or rear deck...also a blade for snow.. I know you do not get much snow in KCY...Start with the used tractor site at Iron.com... search on Missouri, Kansas, Iowa, Nebraska, Arkansas and Oklahoma...use the compact tractor advance search option... this will give you a good feel, most have pictures... you can then decide if you want to hunt for some good deals, look at some Grey Markets, try a Chinese unit (research this thoroughly) or bite the bullet for a new one, either Direct Import, or rebadged Import....
Do not feel you cannot get a quality used tractor, depending on size, for $6,000.... I am not a dealer, but I did buy a very nice Grey Market for way under $6,000... Again, it depends on what you want to do, and what you want to put up with,and how much you want to spend...Thats why there are BMW's owners and those that have Hyundai's...
"There is no such thing as best in a world of individuals" it also applies for tractors....
/ Looking for a tractor #14
Re: $6000 is plenty
<font color=blue>...New Chinese tractors (Jinma, Deadong ...</font color=blue>
Hey Woodbeef...
He may be right "Dead Dong" the Chinese clone of the Korean clone of the Japanese clone... well you kinda get the idea... dog gone.../w3tcompact/icons/wink.gif
/ Looking for a tractor #15
Re: $6000 is plenty
I believe the Kioti's may have been around longer than the Kubota's from what I have read. Not sure who cloned who there :)
/ Looking for a tractor #16
Re: $6000 is plenty
Dong Feng, also sold as TaskMaster.
WillC, if you are interested in seeing a Jinma upclose, drop me an email. Mine is currently stored for winter, but wouldn't have a problem showing and yakking about tractors, come spring. I have had a number of others that have been impressed with the little JM 284. Also, there is a DongFeng distributer in Vestal. Was impressed with the 354s he had.
The belly mowers for the Jinma, don't know if any available for DF, are not the best. If even considering chinese, a RFM is a better choice.
/ Looking for a tractor #17
Re: $6000 is plenty
slowrev
Actually, Kubota is suing Kioti for trademark and trade dress infringement right now. Use of the distinctive orange color and even the hood design are a couple of issues specified in the lawsuit.
Lewis
/ Looking for a tractor #18
Re: $6000 is plenty
I live in upstate NY, but when I look at tractors, I am looking at Ohio, NY, VT, PA - and PA often wins. As for the southern tier of NY, right now in Johnson City there are two Yanmars with implements for less than$5k; and in Greene NY there is a dealer with several used compacts from 5-10. He has a nice 4wd Ford 1700 with canopy, heat, power angle plow for $5995. If you are willing to shop, they're out there!
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
2021 Harley-Davidson FLHP Road King Motorcycle (A61574)
2021...
2005 BOBCAT 323J EXCAVATOR (A64279)
2005 BOBCAT 323J...
2025 Auger Drill Bit Mini Skid Steer Attachment (A61572)
2025 Auger Drill...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
UNUSED ATSPOWER 40 GALLON AIR COMPRESSOR (A64281)
UNUSED ATSPOWER 40...
