Looking for a tractor with front loader
/ Looking for a tractor with front loader #21
mboulais said:
I
Looking at mfg websites to get the same 3pt lift and at least as much wt and as much loader capacity as a Mahindra 2615 4wd I had to go to the 32hp 3320. He would need to drop a bit more coin for that.
That's true...but how many of your implements weigh more then the 790's lift capacities? None of mine...or any I would have any need for.
But, like we always say:
It's only my opinion...
/ Looking for a tractor with front loader #22
George2615 said:
Johnny123,
You can check with Gary's Equipment in Clay, NY, Lawalls Tractor in Batavia (A member here) and Wallace Tractor in PA (Also a member) for starters. I'm sure there are other dealers who may even PM you if they see you're looking for a used tractor. If you make a deal tell them I referred you.
George
My two encounters with Gary's equipment (Mahindra dealer) did not impress me. He can be short with customers and that does fly with me. I have gotten help from Galen Lawall, and would do business with him again any day.
/ Looking for a tractor with front loader #23
mboulais said:
Mahindra makes some very stout tractors. Check tractor wt and 3pt lift capacity of all brands you consider. That 790 won't even measure up to a 20 hp Mahindra. Seriously though, those are both good items to help compare apples to apples along with engine displacement/hp.
I don't think the tractor weight or 3ph lift are very important for most users. I have 3000lbs of 3ph lift and I doubt I'll ever use more than 1100 or so (with the possible exception of lifting round bales - and even then I'll be below 1500lbs). For most CUT owners who have anywhere from 1500-2700 lbs 3ph lift, I'll bet none of them buy an implement weighing over 1000lbs. So 3ph is rarely a limiting factor.
And tractor weight can be good or bad. Thing is, you can always add weight to a light tractor, but never remove it from a heavy tractor. Ever notice you don't see the midsize and larger Mahindras with turf tires? None of the uses you've mentioned sound like they require extra weight. I would worry about an unnaturally light tractor, but none of the major brands (or any minor brands that I know of) are in that category. Kubota is typically the lightest in a class and they have an excellent quality reputation. Excessive weight often indicates cruder construction or metallurgy. Also, the extra weight of the bigger Mahindras is in the engine and frame, largely centered in the chassis and therefore of limited use for counterbalancing the FEL lift or a heavy 3ph mounted implement. If you look at big ag tractors doing big tasks you will generally see add-on weight at one extreme end or the other - by using leverage, you minimize the amount of weight you need, and therefore minimize fuel use and ground compaction.
/ Looking for a tractor with front loader #24
I wasn't saying that he is going to need to lift a 2000 lb implement, but what if he decides to build a carry-all and needs to move flagstones for a sidewalk to the back of the property. It will be hard to lift 1200 lbs of stone with a tractor that can only lift 800 lbs.
As far as excessive wieght, there isn't such a thing unless your working on a soft lawn or in a swamp. The extra wight in a Mahindra is from the castings in the rear end and things like a heavier duty axle as mush as anything else. The additional wieght aids in doing chores like pulling a 2 bottom plow (without needing 4wd). Anyone who grew up around tractors should have seen this. A 30 hp 6000lb 2wd tractor from 1960 gets a lot more pulling done than a 30 hp 3000 lb 4wd CUT made last yr. The castings are niether crude or defective on a Mahindra. I understand castings pretty well, having over 12 years in the aluminum casting industry. Light tractors don't mean poor quality either, just lighter duty design. BTW your 5105 is heavier than my Mahindra 4110. That doesn't make it crude or mean it has metallurgical defects does it?
/ Looking for a tractor with front loader #25
All true, but this can be used to justify a lot of things. I'd love to have one of those articulated loaders that can lift 40,000 lbs. Never know when I might want to pick up my barn and set it down somewhere else. My point is that for the way most people use CUTs and SCUTs, the 3ph lift is not a limiting factor.
I strongly disagree that "there isn't such a thing" as excessive weight. Every pound you don't need burns fuel and compacts the soil. For any task at all, you are better off with the minimum weight you can safely and reasonably perform the task with. Yes, this will be a lot of weight in many cases, but that doesn't mean more weight is always better. My 5105 with filled rears has plenty of traction to do serious tillage, but its weight makes it out of the question for finish mowing on my lawn. I would like to see a pulling contest between a 3-ton 2wd and 1.5 ton 4wd. The 2wd should have a slight advantage since most tractors put more weight on the rears, but it definitely won't be a 2:1 advantage. And the 4wd is a lot less likely to get stuck in mud or with an inexperienced operator.
Moreover, all this is talking about pulling power. How many CUT owners really use their tractors primarily for tillage? Only a few, I would think. For mowing and material handling, the pulling power is of little importance.
I haven't seen a Mahindra in person, and let me be clear that I'm not saying they are poorly made tractors. Instead, I am saying that extra weight is not inherently a sign of strength or usefulness. Mahindra makes a huge advertising deal of their extra weight and all the wonderful things they think it does. I think it mostly burns extra fuel and causes soil compaction.
/ Looking for a tractor with front loader #26
Z-Michigan said:
I would like to see a pulling contest between a 3-ton 2wd and 1.5 ton 4wd. The 2wd should have a slight advantage since most tractors put more weight on the rears, but it definitely won't be a 2:1 advantage. And the 4wd is a lot less likely to get stuck in mud or with an inexperienced operator. Moreover, all this is talking about pulling power. How many CUT owners really use their tractors primarily for tillage? Only a few, I would think. For mowing and material handling, the pulling power is of little importance.
Just look around your area for an antique tractor pull this summer to see what those old 2wd tractors can do. I never said it was a 2:1 ratio, but if someone wants to plow garden, they need enough tractor to pull at least a single bottom 12" plow. My comparison was about ability to pull/plow. The weight will also help when pushing snow down a long driveway. The advice I gave him is considered conventional wisdom by everyone I know who has used tractors for most / all of their lives. It applies to any tractor application, If I was looking for a tractor for mowing lawn and real light work only I would start comparing 20 - 24 hp machines using those same criteria. I did not recommend a 60 hp ag tractor for johny123. Even the heaviest tractor around 28 hp - 32 hp would be usable for mowing a lawn with an RFM and would pull a single bottom plow in most soil types. I know a guy mowing his lawn with a 38 hp kubota with an RFM and turf tires. Most brands offer turf tires up to 40hp . I know Mahindra and Kubota do. I am impressed with my Mahindra and proud of it, but my advice is to shop around and those are they measurements I use along with cost, dealer support, and dealer location. Too many people narrow the search to John Deere and Kubota right away without comparing features. When I was shopping for my tractor I instinctively looked at Case/International and Massey first becuase that's what I grew up around and my first two tractors were those brands too, but I found that Mahindra offered the most bang for my buck, closest dealer, and the best reputation for dealer support in the area.
/ Looking for a tractor with front loader #27
There has been much discussion about weight being good or not so good. It really depends on the tasks. Plowing, heavy loader work, backhoeing, fork lifting, digging and serious ground engagement - give me a heavy tractor. Mowing, spraying, spreading, general non-ground engaging - give me a light one. It's that simple. When chores are equally weighted between the two, then removable weights or a "middle weight" tractor makes sense. For me adding, removing, and storing weights is a PITA.
/ Looking for a tractor with front loader #28
Around this area weight in a tractor is a good thing but most are used for ground engaging work. I was looking at a restored JD 630 yesterday, only approx 50 hp but it had the weight. I can't add much to what Coasterez has said, I think his comments make sense. I had a smaller JD with front weights and that did get to be a PITA when you wanted to remove the loader and do mowing jobs.
:confused: I'm still searching..I like the looks of the Kioti tractor..They look like they a built stronger than the Mahindra's are....So how about some comments on the Kioti tractors...:rolleyes:
/ Looking for a tractor with front loader #30
I puchased a Kioti CK35 w/ FEL and BH a month ago. I shopped all the major brands, including Mahindra, and the Kioti offered the best value and dealer for me.
I love the Kioti, put 35 hours on it so far, everything from grading driveway, digging trenchs, to tilling garden and food plots. This weekend I tipped trees and dug about a 10 stumps.
/ Looking for a tractor with front loader #31
I purchased a NH 1720 last July with 245 one owner hours on it for $7K including my older Yanmar 1700. It included a nice 5' box blade from Woods. I feel that any of the major brands will serve you well. Just make sure that the dealer you choose has been in business for some time and has a good reputation for repairs.
As far as weight is concerned, I can tell you from my experience that my Yanamr weighed in at around 1800# with loaded rears and my 1720 weighs in at around 3300# with loaded rears. I use my machine mainly for finish mowing with a 6' RFM. Personally, I would not want much over 3500# for finish mowing on my soil. But I can tell you that the 1720 will work circles around the little Yanmar. Part of that is the extra weight of the machine combined with the 4 wheel assist of the 1720.
On another side note, I can tell you from personal experience that ANY Yanmar powered machine should be very dependable. The 790 JD fits that description. The 790 is a fine machine. It's DESIGNED to be lighter. Being a LIGHTER YANMAR does not make it inferior, JUST LIGHTER. Don't be scared of the 790. It's Yanmar powered. That's good enough for me.
That last paragraph was paid for by Roy Jackson. LOL
Just kidding Roy.
/ Looking for a tractor with front loader #32
That's cool, dude.
/ Looking for a tractor with front loader #33
I just looked at their website. The DK35 looks almost like an exact match to Mahindra 3510 in wt, hp, lift, hydraulic flow, etc... I would test drive one.
Some features I see on the website that stand out are:
The flip up pto guard is a great idea, wish my Mahindra had it.
The extendeable lower 3pt arms look handy, mine are kinda short.
The 3pt stabilizer arms look like a better design.
The power steering cylinders appear to be behind the axle, Mahindra has them in front.
/ Looking for a tractor with front loader #34
That's the thing about Kioti, more features, stronger attachments, better warranty, and less expensive. They are great machines.
/ Looking for a tractor with front loader #35
On the PTO guard, are you serious? Every other major brand has a flip-up PTO guard. I'm surprised Mahindra wouldn't. The "extendable" lower draft arms are the same telescoping concept that is optional or standard on most of the majors. They extend for hooking up, but you have to back into the implement to lock them in place before working with the implement. Almost all the majors except Deere use the same design that Kioti and Kubota use, while Deere has its own design that does the same thing.
/ Looking for a tractor with front loader #36
Love my CK25. I'm only at about 150 hours, but it seems every bit as good as any other make.
/ Looking for a tractor with front loader #37
If you can't leave the extended, they're not the great idea I thought they were. And no my pto guard doesn't flip up. It didn't on my 1950's Massey or my 1960's International either. I guess if I had paid $7k more for my tractor I would have had that feature and green paint.
/ Looking for a tractor with front loader #38
They do look like good machines, I believe the engine in a DK35 is the same engine as in a Mahindra 3510 and the engine in a DK45 is the same as the engine in a Mahindra 4110. What sort of warranty do they carry? Mahindra is 3yrs powertrain and I think the other stuff is 1yr.
/ Looking for a tractor with front loader #39
Kioti warranty is 2 years bumper to bumper, 4 year powertrain.
Daedong makes the Kioti engine, and is the parent company of Kioti. They do also sell engines to others.
The telescopic rear arms are a very nice feature. I've had both and the telescopic saves alot of time and aggrivation. It's no big deal to lock them back in place, just backup the tractor with the implement down and they snap back in. After having them, I wouldn't want another tractor without.
/ Looking for a tractor with front loader #40
That is a good warranty. When I saw the telescoping arms, I though how handy that would be if you could adjust how far behind you the implement was. I have had several large stones pull out of the ground in front of the box blade and wedge up against the back tire. I am sure they are handy for what they were intended for.
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
(INOP) YANMAR VIO35-5 UNIVERSAL EXCAVATOR (A62129)
(INOP) YANMAR...
John Deere 2555 Tractor with Loader (A61166)
John Deere 2555...
2025 Heavy Duty Booster Cables (A61568)
2025 Heavy Duty...
2025 12v Fuel Pump (A61568)
2025 12v Fuel Pump...
iDrive TDS-2010H...
