Looking for a string trimmer. Any opinions?
   / Looking for a string trimmer. Any opinions? #32
It worked for me, but I had to tell NoScript to "allow the page" in order to do so.
Steve
worked for me as well
I'm impressed ! a solid steel shaft trimmer for under $200.00 !
   / Looking for a string trimmer. Any opinions? #33
Not knocking the 4 strokes,but some time ago my son was in the landscape business..He bought some commercial 4 stroke trimmers ,and some 2 stroke commercial trimmers..
The 4 strokes (after a little use) stayed in the shop ,as he was always having starting issues.. They would always adjust the valves, and give them back to him..They would start fine for a while,then back in the shop for valve adjustment...He finally sold the 4 strokes ,and replaced them with 2 strokes..
Maybe they are making them better now, but I'm not buying a 4 stroke until I have to
I have had great luck with the Honda 4 strokes but I use marine grade stabile year around.
   / Looking for a string trimmer. Any opinions? #34
I have an old flex shaft Weed Eater [Poulan, etc] cheepo string trimmer that I have used for many, many years. Starts and runs great, but has a lot of hard hours on it. Even take it out in the woods and trim small trees with it. Bought a new Toro straight shaft trimmer about a year ago. The old trimmer rotated clockwise, and got used to running the trigger with the right hand, meaning the krap coming off the trimmer was flying away from me most of the time. The Toro rotates CCW [ since it has a gear in the head ], meaning all that stuff is flying right at me. Plus the Toro is longer and heavier... I am going to be looking for another cheapo one and hang the Toro on the wall to collect dust...
   / Looking for a string trimmer. Any opinions? #35
I use nothing but synthetic 2 cycle oil, with pure gasoline (non ethanol)..With the saw blade on my trimmer,,,,I have cut down some 4'' trees
   / Looking for a string trimmer. Any opinions? #36
I don't know anything about the new stuff. I'm still using my 28 year old Homelite st175 straight shaft trimmer. Replaced the fuel lines and primer bulb a couple of times and got a good used string head from a friend to replace the original I wore out.
   / Looking for a string trimmer. Any opinions? #37
The best trimmer I have ever owned is a Homelite, home owner model, I got at the Restore. I don't baby it, don't drain the gas, and it starts in spring with a few pulls.
The rest was all varying grades of Stihl, brand new and I would not give you a nickle for all of them! Mostly for hard starting issues, and the inability to throw them far enough when they don't!
   / Looking for a string trimmer. Any opinions? #38
The 4-mix Stihls are stout! I just purchased an FS 130R for $379. Now let me tell you I wasn't looking to spend that much on a trimmer but this thing is a true machine. It sounds like a small dirt bike running. I use the brush blade and cut saplings the size of my thumb with ease.
The torque is ridiculous. You can put it in the middle of the thickest weeds around then just goose the throttle and it cuts with ease. Super good torque. The head design keeps weeds from getting wrapped and tangled up which is a major plus. It's also super easy on gas. Probably uses a third as much as my old 2 stroke. Much quieter too.
It starts with ease. It has an assist device that makes it easy enough a kid can pull it.
Buy a Stihl FS 110 or 130 and I promise you won't regret it. It's a little more money but it will easily last you 20 years with some care and basic maintenance. Not that I love weed whacking or anything but this thing truly is a pleasure to run if you must trim up.
I have a Stihl chain saw with the easy-start feature and I love it.
   / Looking for a string trimmer. Any opinions? #39
   / Looking for a string trimmer. Any opinions? #40
I have an Echo that does not use the reel of string; it uses two pieces of string that have to be inserted every time you trim. I love that feature, because it eliminates the pain of messing with the reel, but it does require that you insert new pieces at least once, at least in my yard. I also love it's light weight, although I do get the "String Trimmer Shakes" occasionally. It normally starts really well, but have taken it in for service after about 4 years. Apparently the carburetor on this model is not up to snuff; man said it would just about as cheap to buy a new one than it would be to replace the carburetor.
I have an Echo as described above. I love the two piece inserted method head. VERY easy once you get the hang of it. Just cut a few pieces, put them in your pocket and replace as needed. I find using the line a little thicker and with the rougher surface makes each piece last quite a while...and I do some rough cutting with mine. I have two as I just moved my old (6-8 year old) one to our cabin as I got tired of taking one with each time needed. :) TMR BTW...really easy start
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2025 Nationcraft 8.5X36TTA3 38ft Tri-Axle Enclosed Trailer (A59231)
2025 Nationcraft...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
