Looking for a fuse/switch panel
/ Looking for a fuse/switch panel #1
jdgreg
Warrenton, Va
Got a Curtis cab on my JD 4210, and looking for fuse/switch panel to run all my accessories thru. I've seen the one from Curtis, seems a little $$$. Was wondering if anyone else has found a good panel for running work lights, fan, heater, etc, thru it.
/ Looking for a fuse/switch panel #3
Radio hack and grangers makes lots of switch boxes.
Soundguy
/ Looking for a fuse/switch panel #4
Take a look at marine supply stores, waterproof and real brass contacts and reasonable.
Jim
/ Looking for a fuse/switch panel #5
I agree on the marine stores.. Many times you can get grease potted switches.
Soundguy
/ Looking for a fuse/switch panel #6
Inside a cab? meaning it doesnt have to be weather tight?
BY far the best guy to get switch setups is this dude
http://www.12voltguy.com
a very very small sample
you can also just buy switches, fuse blocks etc from him.
/ Looking for a fuse/switch panel #7
Hmm... i think I'd still want weatherproof switches.. even in the cab... Might be humidity differences... I'd hate for an important circuit to fail because I saved a buck on a switch..
Soundguy
/ Looking for a fuse/switch panel #8
Soundguy
Soundguy I agree with needing waterproof switches but those panels that he pictured aren't cheap. Did you follow the link and check the prices? Marine switches are cheaper in my opinion.
/ Looking for a fuse/switch panel #9
I did not check the link.. they looked too $pendy for me. I can wire up an electric circuit in an enclosure box just fine without spending what he probably charges. And yes.. for an switch that is on an outdoor piece of equipment.. marine grade is a good safe bet.
Soundguy
Thanks for the info guys, keep planning on stopping by a Boater's World store that's close to my work, see what they have. Seems most of what they have are the fuse/switch panels, would have to fab a box to mount inside the cab.
/ Looking for a fuse/switch panel #11
JD greg. You should be able to get a good aluminum chassis box with lid for any good industrial electronics supply. Many different sizes are available.
Mount your switches in that.
2020 CATERPILLAR 259D3 SKID STEER (A65053)
2020 CATERPILLAR...
Aluminum Alligator (A65583)
Aluminum Alligator...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
2025 Swict 84in Bucket Skid Steer Attachment (A64553)
2025 Swict 84in...
Bandit 200XP 1695 Hrs (A63689)
Bandit 200XP 1695...
