Looking at ls xj2025h
   / Looking at ls xj2025h #21
Ours has the 12. My reasoning was that a more narrow bucket maybe hard to release the soil if you are working in a wet area. Correct or not? Our dealer gave us three options, which I don't think affected the price.
Mine has a 12" A 9" would be fine but I wouldn't go larger than 12" I've heard size matters.
   / Looking at ls xj2025h #22
I was excited about the specs of the xj2025h went to Ocala and drove one it had loader.I was amazed at the vibration the rough ride and the jerking of joystick.I have a ck20 kioti about 12 yrs old and it rides a lot better and does not have the vibrations.I,m an old guy and that bouncing really discouraged me and the vibration at engine idol was terrible.Maybe the weight difference is a factor.
Check the air pressure in the tires. Most tractor tires have way too much air pressure when sitting at the dealer. They will ride like a wagon every time.
Like others have stated the joystick issue is probably just faster hydraulics than your used to.
   / Looking at ls xj2025h #23
I own a J2023 & I built a pallet fork attachment which is way overkill on sturdyness & I can lift 800lbs. from the back of a truck bed. The attachment w/ forks weighs close to 300lbs. I removed 10- 80 lb. bags of cement including pallet.
Also, I know the loader lift capacity is 1270lbs, minus the weight of the attachments to lift. What's realistic weight I could unload with forks? I know it's limited on its curling weight, but what weight could I unload from a freight height deck? I'm thinking 700-800lbs would be max.
I also plan on building a fork setup. Do you have any pictures of your setup? Thanks, Matt
   / Looking at ls xj2025h #25
Here are some photos.
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2021 Ford F-450 (A55973)
2021 Ford F-450...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A56435)
2019 Cadillac...
1998 Homemade S/A 12x6.5ft Trailer (A56859)
1998 Homemade S/A...
2011 20ft. Anderson Lowbed Trailer (A56859)
2011 20ft...
2019 Ford F-550 (A55973)
2019 Ford F-550...
