Looking at ls xj2025h
   / Looking at ls xj2025h #21
Ours has the 12. My reasoning was that a more narrow bucket maybe hard to release the soil if you are working in a wet area. Correct or not? Our dealer gave us three options, which I don't think affected the price.
Mine has a 12" A 9" would be fine but I wouldn't go larger than 12" I've heard size matters.
   / Looking at ls xj2025h #22
I was excited about the specs of the xj2025h went to Ocala and drove one it had loader.I was amazed at the vibration the rough ride and the jerking of joystick.I have a ck20 kioti about 12 yrs old and it rides a lot better and does not have the vibrations.I,m an old guy and that bouncing really discouraged me and the vibration at engine idol was terrible.Maybe the weight difference is a factor.
Check the air pressure in the tires. Most tractor tires have way too much air pressure when sitting at the dealer. They will ride like a wagon every time.
Like others have stated the joystick issue is probably just faster hydraulics than your used to.
   / Looking at ls xj2025h #23
I own a J2023 & I built a pallet fork attachment which is way overkill on sturdyness & I can lift 800lbs. from the back of a truck bed. The attachment w/ forks weighs close to 300lbs. I removed 10- 80 lb. bags of cement including pallet.
Also, I know the loader lift capacity is 1270lbs, minus the weight of the attachments to lift. What's realistic weight I could unload with forks? I know it's limited on its curling weight, but what weight could I unload from a freight height deck? I'm thinking 700-800lbs would be max.
I also plan on building a fork setup. Do you have any pictures of your setup? Thanks, Matt
   / Looking at ls xj2025h #25
Here are some photos.
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2022 Ford Escape S AWD SUV (A54815)
2022 Ford Escape S...
Butterfly Artwork (A55758)
Butterfly Artwork...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56435)
2006 Heil Tanker...
2013 Nissan Rouge SUV (A56859)
2013 Nissan Rouge...
2015 Nissan Altima Sedan (A54815)
2015 Nissan Altima...
