Longer bar for Stihl M261 - relative novice.
   / Longer bar for Stihl M261 - relative novice. #71
I’m going to go with the guys who said get the longer bar but keep your shorter bar & chain.
Good plan. And you can always run skip chain on longer bar and full comp on shorter bar. That's what I do with my 85cc saw, 28" with full comp and 36" with skip.
That being said, I now have 20” bars on all four of my Homelite super EZ Autos; the one I bought new in December 1974 was the last to switch from 16” to 20”. (I’m sure you can guess my favorite small saw.)
I had a Super EZ Auto. Totally different animal than a modern MS-261. The EZ Auto's and their variants ran super-low RPM's and chain speeds, versus today's saws. They had comparatively higher torque, and had no problem pulling a longer chain, as a result of that.
Those Super EZ Auto's were only 40 - 45cc, if I recall correctly, but had no problem running the same length bar that you'd put on a 55 - 60cc saw today.
Whatever you do, don't buy a new Stihl bar (the ones with the funky design on them), they aren't all that good. Having said that, not my personal poinion, only what I've read about them.
I stopped buying Stihl bars when they got rid of the grease hole for the nose sprocket bearing. My two most recent were Tsumura Total and Windsor Speed tip, and I like both, but neither are very light.
The new Stihl lightweight bars are supposed to be pretty good, good enough that I might ignore the lack of a greasible nose and the silly foo-foo design that looks like it belongs in my mother's kitchen, ca.1995.
My dislike of non-greasible bearings has nothing to do with grease life or how a sealed bearing can perform over decades, but everything to do with hydraulic action, the ability of grease to eject wood chips and long-strand fibers generated when noodling large rounds. I've lost more than one bar in the past to long-strand wood fibers binding up around a sprocket nose.
Again, 20" is more than adequate for all but the largest trees anyway, least in my view it is.
Up to 40" diameter, in theory, but more practically 36" to 38" diameter. I cut a lot of trees over 40", so I use a 28" bar most of the time. I keep the 36" for those occasions when I need to cut something over 55" (literally once per decade), or more commonly, occasions when I need to fell a 30" tree without accessing it from both sides.
What's all the fuss. The MS261's I have all came with 20 inch bars from the dealer. They work just fine.
lol... maybe for you guys cutting pines and firs in the west. :p Using a saw that small with a 20" bar in any large oak would be an exercise is self-torture.
   / Longer bar for Stihl M261 - relative novice. #72
I offered $800 and of course he balked, but $800 is almost 60% of new and that’s right about what % of new that solid used equipment should sell for.
I'm with you. Whenever selling used equipment, I figure on 50% of new. Even if new and clean, you're still expecting buyer to assume risk of a no-warranty transaction. $1000 for used vs. $1400 for new, I'd just buy new to avoid the hassle and have a warranty.
And xyz123 makes a good point about the torque of the 661 that I missed. He knows way more about individual models than me. I'm just a guy who makes a crap-ton of firewood for personal use, I think he actually works on saws as a business.
   / Longer bar for Stihl M261 - relative novice. #73
I use a stump grinder myself, No putting a chain in the dirt, what a carbide toothed stunp grinder is for.
You aint stump grinding all of this off. :ROFLMAO: 🤦‍♂️
Hazard tree was no way to drop as one. But you wouldn't understand that.
Thats why it was stumped by me so I could have my guy bring his grinder in.
Once stumped then grinder work. 🤦‍♂️ :ROFLMAO:
   / Longer bar for Stihl M261 - relative novice. #74
Someone say carbide chain. The good stuff by stihl. ;)
Got to pay to play in the crap stuff. ;)
Why I bought 2 loops and carbide wheel.
   / Longer bar for Stihl M261 - relative novice. #75
I have a Stihl 25” lightweight bar and there’s no such nonsense on it.
I haven’t found that to be the case, but to each his own. I definitely wouldn’t want to run a 261C in hardwood all day, but haven't had much trouble running mine through 18” to 20” hardwoods like this ash. Cut this stuff like a champ.
   / Longer bar for Stihl M261 - relative novice. #76
If I add a 36” lightweight bar it’s $1,519. Problem with a new saw is it won’t see enough use. Thats a crap ton of $.
Which keeps leading me back to a used….
Just need to find one for $800 or under.
   / Longer bar for Stihl M261 - relative novice. #77
Yeah, yours is a lot better. The bar about which 5030 was writing, and to which I was responding, is these goofy things:
I can only assume Martha Stewart was somehow involved. :p
Two things:
1. Yes, it'll do fine. But like you said, a 20" bar buried beyond the nose on a modern high-speed 50cc saw is not something I'd want to run all day.
2. I was really referring ot the case of cutting larger diameters, when I said "nose buried". The horsepower required to keep chain speed up really spikes as soon as the diameter of the wood exceeds the length of the bar, as pulling that chain around the end of the bar while in a blind cut creates a whole heckuva lot more drag. So I believe you, cutting 18" hardwoods with a 20" bar on a 261 is probably fine. But cutting 30" hardwoods with the same bar is going to be much harder on that small motor.
   / Longer bar for Stihl M261 - relative novice. #78
Back when men were MEN!
Actually I didn't know until I looked you can still buy a 2 man saw like that.View attachment 3558095
They are called misery whips and I can tell you from experience they are just that!! The art of sawing with them is to only pull from your side and never push.
This is the quote I received for a Stihl MS462 wrap handle.
1 - 20" bar with 2 extra chains
1 - 25" bar with 2 extra chains
I went ahead and asked about Carbide chains.... well... THAT won't be happening.
1 - 20" - $409.99 + tax
1 - 25" - $479.99 + tax
   / Longer bar for Stihl M261 - relative novice. #80
Their chain and bar prices are about 30% higher than elsewhere. Heck, you can pick up Stihl 33RS-72 chains on Amazon for $30, and no one ever claimed Amazon is the cheapest source for anything.
No comment on the powerhead price, I haven't shopped new powerheads in years, but if their chain pricing is any indicator...
I'm willing to pay 10% more to support local business, but usually not 30% more.
2014 Dodge Charger Passenger Car, VIN # 2C3CDXAT8EH223963 (A57453)
2014 Dodge Charger...
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
Automatic Tire Changer (New/Unused) (A59225)
Automatic Tire...
SET OF TRUCK FENDERS & HARDWARE (A58374)
SET OF TRUCK...
TIRE & RIM, SKID STEER PLATE, MISC HITCHES & PARTS (A52708)
TIRE & RIM, SKID...
2013 Chevrolet Traverse AWD SUV (A56859)
2013 Chevrolet...
