Long range wireless router help
/ Long range wireless router help #41
Terms of Service does not equal criminal charges. The ISP can make their terms of service say I can only use the Internet while wearing my pajamas, but the sheriff won't throw me in jail because I used the Internet while wearing blue jeans. The ISP can terminate our agreement/contract, because I violated it. They could try to sue me for violating the contract. But I won't be thrown in jail, unless I also violated some criminal code that a group of elected officials created (ie, hacking is criminal, not because its prohibited by my ISPs terms of service, but because of the U.S. Code).
If your locality has a law that says sharing Internet is illegal, then it is. Or if your district attorney interprets other laws as meaning that sharing Internet is illegal, then it might be (probably depending on how good of a lawyer you can buy).
My ISPs terms of service, which I just checked, clearly states that if I "resell or redistribute the Service to any 3rd party", they will terminate my account.
Somewhat funny - It also says that I cannot "Post, transmit, or distribute content that is illegal, threatening, abusive, libelous, slanderous, defamatory, promotes violence, or is otherwise offensive or objectionable." Objectionable? Really? So If I call someone a stupidhead, they can terminate my account? I guess so, but they'd really be shooting themselves in the foot as they'd have to terminate almost all of their customer accounts :)
Keith
/ Long range wireless router help #42
I refer to my ISP as stupidheads all the time, and they've never termina
/ Long range wireless router help #43
Ubiquiti has a very nice product line, and I've used their products to extend my home network into my barn with excellent results. A Ubiquiti Bullet with a yagi antenna should hook you up. Follow this link to get started:
Cyberguys.com - ubiquiti has returned the following search results
BTW, it's not "illegal" to share your service, but it might violate the user agreement of the ISP. The bottom line is that they have no effective way of telling unless the total bandwidth / fair-use-policy threshold is exceeded.
P.S. The effective limit of Ethernet is 300 feet without a repeater. You are much better off going with a wireless hop to your neighbor since direct-burial Ethernet would bankrupt you...
/ Long range wireless router help #44
Ha Ha! I see what you did there! Very funny those ISP pieces of sh
/ Long range wireless router help #45
I did not read all the posts in detail but someone did suggest putting a switch in the middle that would allow two 100 meter runs. Another easy option is to use wireless internet radios such as those available at tranzeo.com (there are other makers).
I am on a wireless internet system where the provider gets his main feed from the telephone company. He uses Tranzeo 5.8 GHz radios to service his main site on a cliff and distributes using 2.4 Ghz radios from there.
My service is fed through two neighbours' sites with back to back Tranzeo radios where one radio receives and then routes out through the second radio operating as an Access Point. The distance to the first neighbour from the main tower is about 10 km, then 2 km to the second neighbour, then 2 km to my house.
The download speed for this system can be up to 4 Mbps but is more typically 1.5 Mbps and can slow to a crawl when other subscribers are downloading movies, etc.
You would easily get in excess of 3 Mbps between you and your neighbour's house at that 600' distance. Of course the satellite feed is likely much slower than that. A couple of my neighbours have satellite and get around 1.2 Mbps download but it also can slow to a crawl at times depending on the loading on the shared system.
You could likely pick up a couple of used older Tranzeo (or similar) radios for around $100 each.
/ Long range wireless router help #47
I have hi speed cable and my son who is a computer expert and lives in a house on my property 650' away from my house rigged a very cheap setup to connect to my internet.
He used a couple of old cans for the antennas that are in line of sight. I am not completely familiar with exactly how he set it up but he said it was very inexpensive and it works perfect. He said this system could easily go another 1000' if necessary.
It is connected to my router and I have 3 other computers in my house on the router and we get fast connections even with all 4 computers on at once.
I do not know the legalities of this setup, however, I own both homes and they are on the same property so I do not see any difference from doing this or using my computer in the other room or my laptop wireless outside on the front porch.
/ Long range wireless router help #48
Those rusty tin cans, even in the state they are in, probably provide at least 10dbd of gain on each end. for a path gain of 20dbd or 100 times the signal strength of a dipole antenna. Noticed he kept the coax to the radio pretty short, and put it under the eve also and ran cat5e to inside the house. Pretty smart guy.
James K0UA
/ Long range wireless router help #49
If you do a google search for cantenna you may find what you are seeking
Not going to comment on legalities.
/ Long range wireless router help #50
are there stringas run between those cans????
Holy smokes guys, I never expected this much of a response. Thanks for all the input!
I am on my mobile phone only for the next day or so, so will try to answer more later but to hit on a couple things.
No electricity between me and the neighbor and any hard-wired option would need to go under a road which isn't really an option.
When I use my aircard elsewhere it works great. At home I get one or no bars and it is terrible.
/ Long range wireless router help #52
Before we got DSL, one of my neighbors, whose house is 220 feet from ours, was paying for DirectTV Internet. ON a good day, I could see the wireless network he was using as an available one on my laptop, but I never tried to connect to it.
As I interpret your post, trying to get internet from a neighbor with their knowledge and permission is not illegal, but if I tried to get internet from my neighbor without his knowledge, would that be illegal?
My wife sometimes takes a laptop to her folks house, and is often able to connect wirelessly to a neighbors Internet, without their knowledge. Is that illegal?
My attitude, right or wrong, is that if you don't want me latching onto a signal then keep it off my property.
/ Long range wireless router help #53
Google Mobile phone repeater or Mobile phone booster. Or look at eBay. There might be models that will make your aircard work.
/ Long range wireless router help #54
So if it is illegal to share your signal with a neighbor then it must be illegal to share it with a house guest as well or even multiple users in the same household, they better start building more jails for this crime spree:laughing:
/ Long range wireless router help #57
I wonder if mounting a Mi-Fi card (cellular internet that provides a home wi-fi connection) up on the roof or a mast would boost the range and provide a home service.
Ken
/ Long range wireless router help #58
One of the great things I have experienced while belonging to TBN over the years is that members are always willing to share knowledge with each other.
The knowledge they provide might not always be correct, sometimes skirts the barriers of legality, might be heavily biased, or opinionated, perhaps ever flat out WRONG now and then.
But what the heck, it's the willingness to share and help other members that makes TBN so great. When I want only facts, I use Wikipedia to provide those.
But when I want opinions and advice, I seek it here. It's a simple as that.
/ Long range wireless router help #60
Or at least encrypt it with WPA2.
Aaron Z
While we would all like to think that because a signal falls on our property, we have the right to receive it (me included). But the courts have found otherwise, and decreed that cellphone, pager etc, communication is illegal to receive or at least to reveal the content.. Even some countries have made certain broadcast signals intended for widespread reception illegal for their own political purposes. The only time I have seen that it was OK to reveal the content of private cellphone conversations when it was done to Newt Gingrich, but that was unusual circumstances as he was a Republican, and they were good Democrat supporters, so it was sanctioned this one time, and they were hailed as heroes.:thumbsup:
James K0UA
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
2018 Yamaha VX1050B-TA Waverunner Jet Ski with2010 trailer (A59231)
2018 Yamaha...
2007 International Derrick Digger Truck (A60352)
2007 International...
2020 BOBCAT E55 EXCAVATOR (A59823)
2020 BOBCAT E55...
Year: 2021 Make: Ford Model: Bronco Sport Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 108700 (A59231)
Year: 2021 Make...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
