/ Long landtrac 530 information help. #1
Blw3
Long landtrac 530
I bought a used 2001 long landtrac 530, I am trying to find manuals on it as well as determine the type of Mitsubishi 3.3 liter 4 cylinder diesel that is it, currently for the purpose of figuring out which freeze plug hole I would be able to install a block heater in. Also I am not sure the type of fluid for the hydraulic system. Any help would be greatly appreciated
Update since posting this for anyone searching down the line, I did atleast figure out the motor is a Mitsubishi S4S 064297
Another update for a long land trac 530 2001/era, this time filters that cross references to atleast fit mine( already installed for the last 4 months)
Oil=wix 57106
Hydraulic = wix 51536
Fuel=napa 3394,
Hope this helps someone searching.
Update: here are photos of all the equipment which has the s4s motor in it for possible part numbers and such. I found it on westdiesel.com
Update since the company went bankrupt and discontinued all manuals, Here are some of the very hard to find information for the landtrac 410 dtc/450dtc/470dtc/530dtc/550dtc
If you was wondering what a landtrac 530 wiring looks like around the steering column, here are a few pictures of mine(already had wires rerouted etc from the former owner) also there is a photo of under the instrument cluster.
Agri Metal Tuff Vac 5000 (A50774)
Agri Metal Tuff...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
Cat 315l Excavator (A50514)
Cat 315l Excavator...
2011 CATERPILLAR M318D MOBILE EXCAVATOR (A51242)
2011 CATERPILLAR...
(3) PIVOT TIRES (A51244)
(3) PIVOT TIRES...
2001 Sterling Acterra Dump Truck (A50514)
2001 Sterling...
