/ Long landtrac 530 information help. #1
Blw3
Long landtrac 530
I bought a used 2001 long landtrac 530, I am trying to find manuals on it as well as determine the type of Mitsubishi 3.3 liter 4 cylinder diesel that is it, currently for the purpose of figuring out which freeze plug hole I would be able to install a block heater in. Also I am not sure the type of fluid for the hydraulic system. Any help would be greatly appreciated
Update since posting this for anyone searching down the line, I did atleast figure out the motor is a Mitsubishi S4S 064297
Another update for a long land trac 530 2001/era, this time filters that cross references to atleast fit mine( already installed for the last 4 months)
Oil=wix 57106
Hydraulic = wix 51536
Fuel=napa 3394,
Hope this helps someone searching.
Update: here are photos of all the equipment which has the s4s motor in it for possible part numbers and such. I found it on westdiesel.com
Update since the company went bankrupt and discontinued all manuals, Here are some of the very hard to find information for the landtrac 410 dtc/450dtc/470dtc/530dtc/550dtc
If you was wondering what a landtrac 530 wiring looks like around the steering column, here are a few pictures of mine(already had wires rerouted etc from the former owner) also there is a photo of under the instrument cluster.
HTC 10' - 100 TON PRESS BRAKE (A60430)
HTC 10' - 100 TON...
UNUSED IRANCH MINI EXCAVATOR WOOD GRAPPLE (A60432)
UNUSED IRANCH MINI...
UNUSED FUTURE FT15P EXCAVATOR (A60430)
UNUSED FUTURE...
(2) 6 LUG WHEELS/GOODRIDE ST225/75D15 TIRES (A60432)
(2) 6 LUG...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2020 Kubota RVX900 4x4 Diesel Utility Cart (A59228)
2020 Kubota RVX900...
