LONG front end loader moves slow ?
/ LONG front end loader moves slow ? #1
Matthew27808
BATH
1998 New Holland, 1725 , 1981 Long 510
Hi guys
I have a front end loader that rises very slow but is a little faster when the RPM are up. The pump is fine, thats verified. When you pull the control lever it drops about a inch and then goes up slowly but is still very strong lifting and the curl is fine. Could it be that one or both the Lifting Rams have bad packing ? Any thoughts ?
Thanks
/ LONG front end loader moves slow ? #2
If you quick disconnects on the hoses I would suggest carefully swapping the hoses for lift / lower to the curl / dump function. If the loader lifts fine but curl now is slow you could have valve issue.
Dropping a little before raising could be a load check leaking.
I don't have quick connect but I still can switch them. That way if that don't work it would eliminate the valve.Thanks, I'll try that.
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
2014 Chevrolet Silverado Pickup Truck (A62613)
2014 Chevrolet...
2005 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A64194)
2005 Chevrolet...
2016 Ford F550 Crew Cab 4x4 Flatbed Truck (A62613)
2016 Ford F550...
