logsplitter won't split
/ logsplitter won't split #1
dalevs
i have an old 1970"s mtd splitter and the ram goes out real slow and no power at all.i put a new 11gal. 2/stage on it and no difference at all.when the ram goes out it is real spongy,you can kinda push it back alittle and it kinda springs back & then continues forward very slowly the stops when it hits the wood.ther is no way to check the fluid(30wt HD oil) in the cylander.only a little weep hole plug at end of cylander.when i opened it real foamy oil did come out.can you help me...pleaaase.....Dj
/ logsplitter won't split #3
Welcome. Perhaps post this in another forum such as rural living and you will get more replies. I'm not a hydraulic expert but you probably need to replace the fluid as it sounds like you have air in there and or not enough fluid.
Good luck.
/ logsplitter won't split #4
Post in Hydraulics.
Make sure there is fluid in the reservoir and the suction line from the reservoir to the pump is clear.
/ logsplitter won't split #5
You really need to put a pressure guage on it to see what kind of PSI you are developing. That will do wonders when trying to diagnose hydraulics:thumbsup:
/ logsplitter won't split #6
I am betting the seals on the piston inside the cylinder are bad, and they are bypassing fluid...it needs to be rebuilt.
iDrive TDS-2010H...
2007 PETERBILT 386 T/A 6X4 SLEEPER TRUCK TRACTOR (A59908)
2007 PETERBILT 386...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2019 CATERPILLAR 246D3 SKID STEER (A62129)
2019 CATERPILLAR...
2003 V.E. ENTERPRISES 500 BBL FRAC TANK (A60736)
2003 V.E...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
