Logsplitter Update Welds held design didn't!
/ Logsplitter Update Welds held design didn't! #1
1grnlwn
Central Illinois
bobcat 773
Well a design problem coupled with a bad decision on a 4' dia crotch ended in this.
/ Logsplitter Update Welds held design didn't! #3
It's hard to tell exactally what I am looking at.
Is the wedge welded to an I-beam, or box tube.
If box-tube, how thick was/is it.
If you could, could you take some more pics standing farther away. I am just having a hard time picturing it.
Problem was, I welded the wedge to the 8" x 1/2" plate instead of welding it directly to the top of the beam. The 1/2" plate flexed and tore open like a old fashion beer tab.
/ Logsplitter Update Welds held design didn't! #5
Like Bob said, the support shoud go back further behind the blade so all the strain is not on the front of the weld.
On the positive side the welds are fine, no sachasm(sp) intended....Mike
/ Logsplitter Update Welds held design didn't! #6
Put the same wedge profile in the web area of the girder to prevent the top flange from moving and to spread the load.
/ Logsplitter Update Welds held design didn't! #7
Tear out in the heat affected zone of the weld.
If you can extend the blade below the base surface and weld a big gusset between that blade extension and the base you can probably add enough strength to prevent that happening again.
------------------------------ ___
----------------------------\--___
1767 (A64280)
1767 (A64280)
2013 International 4300 Bucket Truck 55' (A62613)
2013 International...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
Ford F800 (A63689)
Ford F800 (A63689)
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
TerraGator L3020G4 (A64119)
TerraGator L3020G4...
