Logging winch- New user with questions!
   / Logging winch- New user with questions! #71
Wire was fine I am just taking extra steps to make sure it does not happen again. My solution works fine but is not very elegant I tough there must be a better way to do that.
   / Logging winch- New user with questions! #72
That was an interesting read, hslogger.
How do you get a good coating on your cable without also getting it on your clutch/brake? It would seem there is a pretty good risk of that if you just dump it on your spool (my spool is also difficult to reach). It would also seem that you wouldn't get good lubrication throughout your cable. I don't relish the thought of unspooling all 230 feet to apply the length of the cable - and as the article you linked notes, it's better to oil when it's flexed and under some tension (on a spool or pulley) since that opens up the wraps a bit.
I agree, interesting read, and I'm not saying it's wrong, but it might not apply as much as the article is about mostly industrial machinery in a different environment than logging winches, IMHO. They are really referring to technical aspects of winches uses on cranes and the like, which also get dirty, but not in the same way. Cranes and what else they mentioned are mostly overhead lifting uses, not direct ground contact dragging through dirt, leaves etc.
I'm all for lubing things, but the inherent risk to the drum clutch is way more of a concern than having to replace a wire rope cable when it is past it's useful life due to frays, kinks, broken strands of wire, etc. I suppose if one were heii bent on lubing their wire rope I would extend it all the way out less a few feet left on the drum, and spray it when it's taught to a tree or similar on a sunny summer day. If possible I'd leave it sitting in the sun until the best 'dryest' lube available were soaked into my wire rope and had saturated through its entire-section:thumbsup:. Once dry I would wind it back onto the drum, and go from there. If it turned out to 'grease' the clutch disc - I have no solutions other than using Brakleen and compressed air to try to degrease the disc and hope for miracles...
There are dry graphite sprays available now too, which may not be the industrial standard for cranes and such, but might be more suited to logging winches- a compromise so to speak. Let me know when one has done a lubing of their winch wire and what your results are!?:eek:
Like hsLogger said- to each their own.....
   / Logging winch- New user with questions! #73
I thought a "skidding cone" was a safety item. :laughing:
   / Logging winch- New user with questions! #74
After several pages I guess I'm the only cable greaser on here, that's ok I'm used to going without the camp. My biggest cable ware is within the 5 cable slides when winching the trees up because most of trees that I fall are not in a nice neat row, more like zig zag pattern, one of the issues I have when select cutting, at times I have 5-8 trees chain-up so it looks like cats cradle, and thats why I put some grease on my slides and cable, if no grease, I use some oil.
   / Logging winch- New user with questions! #75
I've put Fluid Film on my cable. Kinda a non decision in the "lube/no lube" conversation as water will eventually take it off. I understand the dirt idea creating a grinding compound more or less, but I'm in the woods with mainly leafy matter and no bare dirt. It has to be a help esp. when doing a lot of snatch block work. Pulling around a 4-5" sheave has to be hard on the cable internally and yes the slides have to effect the outside layers.
Anyone replaced with the "swaged" cable here? It's a good bit more expensive.
   / Logging winch- New user with questions! #76
("Anyone replaced with the "swaged" cable here? It's a good bit more expensive.") Rusty, I dont understand the question, can you clue me in?
Fluid Film dont sound like a bad idea to me, if one is logging in the mud, I dont think it matters if lube or no lube, some mud/dirt is going to wound in, one solution is hook up a sprinkler system to spray water on the cable as it it being winched in, or better yet, it's to muddy out there so I'm gonna take another month off.
I almost forgot to mention, the only time I got grease on my Fransgard winch clutch disc so it wouldn't work, was when I put to much grease on the chain that turns the cable drum. I had to tear it all apart and spray the brake disc with brake solvent, put back together and from then on, more careful applying grease to chain.
   / Logging winch- New user with questions! #77
It's ''squished" down for a much smoother surface. From what a friend tells me it's a little stiffer & tougher and stronger for the same size that's meant for your winch.:confused3: Labonville has it in their catalog.
   / Logging winch- New user with questions! #78
No longer have the logging winch, but Fluid Film was what I had used also. No problems with the clutch on the winch. Tried to keep the line as clean as possible, avoided working in mud and stored the winch indoors when not in use. Admittedly, that may not be practical for everyone.
   / Logging winch- New user with questions! #79
Have seen them and if I'm correct the are much less stiff than a ordinary wire.
   / Logging winch- New user with questions! #80
I am not sure lube on a forestry winch cable matters one way or the other except for the clutch issue. Probably the best case for using lube is when your winch sits idle. Lube may help prevent some rust. Winch cables are not used like hi-rise cranes where hundreds and hundreds of feet are spooling on and off all day long and cable friction, internal and external, are the cause of wear. It seems forestry winch cables, at least mine, have to many other things that will destroy them before they will wear out from friction and lack of lube. Maybe this is just me justifying the fact that I am to lazy to lube.
gg
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2012 Ford F-250...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2020 KUBOTA RTV...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
2006 Ford F-550 4x4 Flatbed Pickup Truck (A50323)
2006 Ford F-550...
