Logging winch design
/ Logging winch design #1
tslbogger
trois-rivieres Qc
Case DX26 Simplicity 18hp
Hi
What do you think about this winch design? (Upper link is missing on this drawing)
Hydraulic winch Tulsa 8000 lbs
3/8 wire 150 feets
Will be use at home on our land to recover broken or deads trees with my Case DX26
I allready have the winch and 12 volt hydraulic valve and some pieces of tubing.
Your opinions are welcome.
I can change the design at this point...
/ Logging winch design #3
Waiting for that hydraulic winch to spool in will try one's patience.
That's a problem with recovery / hoisting winches. If it's got the guts, it's too slow.
pto versions really are best. Like the commercial units.
And I'm not sure a good logging winch can be built for less than it can be purchased for. Cost per pound etc.
/ Logging winch design #4
I've skidded hundreds of trees with my home made outfit and only a 4000 # 12V winch not real fast but adequate . I think you'd be happy to have a fairlead for the cable , depending on your terrain . Can't find a good pick of mine but you can see the fairlead as I'm skidding trees from above ,below and often from the side.
Before I made a log trailer I'd skid 4 or 5 good size logs tree length if I had any distance to go.
First layer speed should be 82 fpm.
I cant justify to spend as much money a pto winch worth.
The hydraulic winch with the motor was real cheap and I have some material on hand.
I will use this winch for maybe 2-3 times by year to recover trees in bad spots or to control falling route.
/ Logging winch design #6
Looks good and be sure to bring us along with pictures of your build.
I built a hyd log winch with similar speeds and I'm happy with it with the tractor at an idle. In my dense and rocky woods approximately a foot per second is plenty fast.
Occasionally I miss the opportunity for more cable capacity but making a pull over 100' (on my woodland) is a challenge mapping out the cable route that won't fight me with hangups or a lot of damage to the trees on that path.
Put a valve on the winch that's accessable from the ground. I find that most of the time that's where I operate it from over being in the seat.
Another minor thing is your drawing shows a typical 3pt. pin. Use 2 sturdy tabs with a pin going through them with the tractors lift arm in between. Too much forces for a "one sided" attached pin.
/ Logging winch design #7
I second what Rustyiron said. Definitely support the lower pins with two ears/tabs per pin.
Do you have a way to free spool the winch?
Unfortunatly, no way to freespool without modification of the winch.
I plan to use a wireless remote to control the hydraulic valve on the winch.
I will add mounting tab on the 3 pt
/ Logging winch design #9
A wireless remote is very handy . I don't have to go back and forth to the tractor to reset the choker to put a roll on the log .
/ Logging winch design #10
Looks good tsibogger. I agree with the other on the clevis type connections to the 3ph. You will most likely be adding hooks and brackets to hang your chokers, snatch block(s), cant hook, and etc. If you haven't thought about those details already it might make it easier later if you do.
You might consider making your receiver tube flush with the face of the blade. Having something for the logs to snag on can be a pain. Having to pin the receiver tube behind the blade is a pain too but to me the lesser of two evils.
gg
40 (A52708)
40 (A52708)
John Deere 1025R (A53317)
John Deere 1025R...
2015 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2015 FORD F-250 XL...
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
