Logging winch cable memory
/ Logging winch cable memory #1
liberty2701
Platinum Member
Lakes region,NH
Kioti Dk50se hst
My Tafjun winch cable developed a memory on the first 40 ft of cable. It wants to coil up like a spring. What caused this and can i remove it ? Thanks
/ Logging winch cable memory #2
Appreciable tension combined with the added stress of flexing it into the wrap. This can overstress the portion of each strand that is on the outer part of the curve resulting in slight bending and the set into a spiral. No point in trying to fix it as it would happen again anyway. The lay up of cable onto a drum has to be well controlled to prevent rub points and cable crossings that accentuate the flex/bend and I doubt small winches provide for this.
/ Logging winch cable memory #3
Pull your wire rope out, hook it to a tree and winch it ---------->TIGHT, lock the brake...
Leave it under tension over night and much of the curl will come out...
SR
/ Logging winch cable memory #4
The last resort is to get another cable, mine starts getting bad anyways after 100 cord.
I guess this is a normal occurence. Has this weakened the cable?
/ Logging winch cable memory #6
Only marginally. ... When it starts to fray replace it.
/ Logging winch cable memory #7
I never had winch cable coil up BUT as it got old and used a lot - it would certainly start fraying. I never had a frayed winch line snap either. HOWEVER - a frayed winch line will pull the frayed ends right thru a pair of heavy gloves and can really cut up your hands.
Its never a good idea to allow a winch line to slide thru your gloved hand for any reason.
For maintenance - at least once a year I would remove the cable from the winch drum, spool it into a five gallon plastic bucket and let it soak in used motor oil for a day. This was a messy operation but it seemed to help the cable maintain flexibility and resist any rust. Now there are products specifically made to spray on/soak winch line.
/ Logging winch cable memory #8
Mine usually starts fraying near the end, I cut it back to the good part and re-clamp, if I get down to around 70', I replace. When I start getting wood I put some grease on my sliders
LS MT225E (A64126)
LS MT225E (A64126)
Husqvarna MZ61 Zero Turn Mower (A66285)
Husqvarna MZ61...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
445 (A63290)
445 (A63290)
INOP/NON-RUNNING 2004 International 4200 Dump Truck, VIN # 1HTMPAFM64H660244 (A65563)
INOP/NON-RUNNING...
(2) New 27X8.5-15 turf tires in John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 27X8.5-15...
