Backhoe Log splitter
/ Log splitter #1
richieg1
Valley stream NY
John Deere TLB 110
This might be a lame question but it comes from a weekender can you hook up a home made log splitter cylinder and control value to the Back Hoe hydraulics without a PTO pump any input would help I just didn’t want to go out and buy a $500 pump if not needed
Thanks
Richie
/ Log splitter #2
It’ll work but not very fast. Rather or not the pump is worth $500 plus additional parts depends on how much you use it.
/ Log splitter #3
I have a Kubota L3240 and had the backhoe hydraulics piped out for a 3 point log splitter by the dealer. Since it is a open hydraulic system there is a hose from supply to return connections to keep flow moving correctly. Now the log splitter control valve is a open center so when connected flow is maintained. I don’t use it that often but it eliminates another pump, and engine storage problems and the noise from a motor running wide open while splitting. Yeah it’s a little slower but so am I so it works out just right
/ Log splitter #4
FYI, I don't ever run the splitter engine WOT when splitting. Isn't necessary, IMO. Just a bit above idle works just fine.
Besides, the tractor is free to bring logs and move pallets of split wood away as fast as the wood gets split.
/ Log splitter #5
I NEVER run my "pto powered pump" splitter wide open either...
Plenty fast without doing that... It's MUCH faster than trying to run it off the tractors remotes...
SR
/ Log splitter #6
I was talking about a little tow behind splitter, I’ve used in the past, if you want it to work you need to run it at a high rpm. I was just trying to explain my reason for a tractor powered splitter to the OP. I didn’t know it would cause such replies, Im done with this forum.
/ Log splitter #7
This thread never flew off the handle. If you can’t take the replies here it’s probably best that you leave.
/ Log splitter #8
I considered going to a tractor powered splitter for a short moment, but decided that I did not want to stack hours onto a $30,000 tractor to run a log splitting cylinder when for $1,000 I can buy a Woods tow behind with it's own Kohler engine that is about a $300 throw away engine. And as far as sound, I run the Kohler at around half throttle and it is far less noisy than the Kubota engine.
A little tow behind 27 ton Woods splitter will out perform a tractor hydraulics driven one for sure, if you run your PTO to a stand alone splitter pump you can likely get tow behind performance, but to do that you are running the engine and hydraulics on a tractor with a finite life span and a cost in the multiple 10's of thousands of dollars... as in your spending a **** of a lot of money for a power source for that splitter while you could be running a dirt cheap and disposable little utility engine that costs pennies to buy and to maintain.... if you even bother to maintain it. They will run for many years of intermittent use with zero oil changes or maintenance. Ask my father in law... he does not believe in oil changes or maintenance on anything. Somehow he gets 100,000 to 150,000 miles from his Ford box trucks with only adding oil to them a few times a year. When the engines die, he has it replaced with a junk yard engine and goes at it again just adding oil now and again.
/ Log splitter #9
Rock Crawler made a great point. Putting hours on a tractor to split wood does not seem like a smart use of resources. Plus it takes the tractor out of service for the other tasks it is handy for when processing firewood.
/ Log splitter #10
I don’t loose much sleep about the hours put on a tractor, but I’m not willing to give it up for other parts of the operation.
/ Log splitter #13
I looked back at what was posted before he snowflaked out, and I can't see who initiated the tears? Was something edited out... Or am I missing something?
/ Log splitter
Hey guys thanks for all the replies everybody has a legit reason for my lame question I inherited this splitter with a broken pump and some other issues but the ram was fairly new and the control value works so instead of buying a pump and motor and a tank I ask the question about hooking up to the back hoe hydraulics I only use it during hunting season for camp fire wood. As for my answer looks like I can do what I asked with the parts I have just one thing how can I tell I have an open center control value
Thanks
Richie
/ Log splitter #15
It was either beenthere or sawyerrob. Those are the only two that posted before he flaked. I think the bulk of the human race has evolved to the point of smaller brains and thinner skins:banghead: Social media has ruined many people.
/ Log splitter #16
Thanks
Richie
Easy way to see if logsplitter valve is open center.....blow air in the inlet (P) port. If it comes right out the T (tank) port...yep its open center.
Highly unlikely that any cheap stand alone splitter would have anything other than open center.
2007 TEREX ADVANCE MIXER FD3000 AWD 6X6 FRONT DISCHARGE MIXER (A59910)
2007 TEREX ADVANCE...
2012 John Deere 328D Compact Wheel Loader Skid Steer (A61572)
2012 John Deere...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2022 FAE UML/SSL-150 Sonic Mulch Head (A63116)
2022 FAE...
New Holland TC21 (A62177)
New Holland TC21...
2019 ALLMAND LIGHT PLANT (A63569)
2019 ALLMAND LIGHT...
