Log Splitter Wedge ripped off.
   / Log Splitter Wedge ripped off. #1
Scotty Dive
Platinum Member
Ct
Yanmar 2020D
My home built log splitter wedge ripped off tonight. The wedge was already welded onto the I Beam when I got it and it was a welded up mess of hand wedges and steel in a 4 way wedge - Who am I to criticize - it split at least 25 cords of wood for me. Well the top vertical section ripped off and I think the horizontal section isn't really all that horizontal and puts added stress on the system and I am considering cutting the whole thing off and starting new. Looking for ideas - would like to keep the 4 way - the splitter seems to handle it ok - a few pieces get stuck but only the nastiest. Should I go to just a single wedge? Any TBN vendors I should consider? Solutions?
   / Log Splitter Wedge ripped off. #2
Had the same thing happen on my old home built splitter. I got a longer wedge, cut a hole in the top of the I beam and inserted the wedge so it rested on the bottom I beam flange. Then I welded the top, bottom and sides of the wedge to the I beam, problem solved.
   / Log Splitter Wedge ripped off. #3
Judging by the bolt for a brace, I'm surprised it lasted as long as it did. Pretty crappy workmanship. Make a new 4 way wedge at least 6" long and if you don't have enough skill, get an experienced welder to weld it with 7018. A 3 pass fillet about 5/8" to 3/4" all around it would be plenty strong enough. While your at fix up the welds on the cylinder mount. There's a lot pressure and you don't want pieces flying if it breaks. Some log splitters use a vertical I beam welded behind the wedge for added strength.
   / Log Splitter Wedge ripped off. #4
+1 Look at the weld or lack of on the top wedge, it looks like 1 small stringer bead at best. No wonder it broke. A slip on wedge for the 4 way works well also, then take it off when you don't need it. Great plains has them sometimes. CJ
   / Log Splitter Wedge ripped off. #5
My homemade wedge has the Ibeam behind it also and no problems in 4 years.
I think I am going to try to repair it. I can mig a little but do have a new to me stick welder and this would be a good project for me to get some experience. Even if a spend a few hours putting this back on and it fails I will be better off getting some real world experience and can just cut it off and install a brand new wedge later and I will be a little smarter when/if I do.
Arc Weld - you mentioned 7018 rods. I do have a box of 1/8" 6011 - would that suffice or are the 7018 far superior for this project especially for someone with little experience? And, three passes at a minimum and bevel back the edges before welding right?
   / Log Splitter Wedge ripped off. #7
I'm a self taught welder and the 7018 are harder to use. I welded a bunch on mine with 6011 and all ok so far.
   / Log Splitter Wedge ripped off. #8
If it was mine (and it's what I have) I would use a single wedge (knife) and make a slip on 4 way. I like having the option of taking it off and I also have a 6 way for special wood.
   / Log Splitter Wedge ripped off. #9
   / Log Splitter Wedge ripped off. #10
I would grind off the welds that are on top, clean up the top wedge, bevel the top wedge with large bevels, use that 6011 rod.
2006 International 4400 LP Ambulance (A50323)
2006 International...
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52128)
2003 International...
2016 Ford Fusion Hybrid Sedan (A50324)
2016 Ford Fusion...
2005 MACK GRANITE GU713 DAY CAB (A51219)
2005 MACK GRANITE...
