Log Splitter Wedge ripped off.
   / Log Splitter Wedge ripped off. #11
You can buy a replacement wedge from Northern tool that's made from harden steel.
   / Log Splitter Wedge ripped off. #12
Welding dissimilar metals takes much care. You don't want that hardened steel cracking right next to the weld.
   / Log Splitter Wedge ripped off. #13
The big problem with the horizontal portion of the wedge is the thickness & have an angle on the underside of the horizontal portion of the wedge. By having only one edge beveled & on the top side of the horizontal splitting edge, you will not have the lower split piece of wood being wedged between the beam & the wedge. Get a piece of 1/2" thick plate 16" long & 6 - 12" wide. Along the 16" edge cut/grind a bevel on one side only at approximately a 35-40 degree angle. When you weld this to the top of the vertical wedge keep the beveled edge up & positioned around 2" back from the vertical wedge. This way you will be splitting in 2 stages, left/right, then up/down. I would also use 1/2" flat to make a vertical wedge to go on top of the horizontal portion which is 8" tall. Bevel both sides of this piece & have it lined up with the bottom edge. 4 Way in place.jpg
It is possible to make this add on "4-way" removable. It is not an adjustable height, but it is easy to add on & remove. In a nut shell I had a piece of 2.5" square tubing welded to the back of my stationary wedge . I slid a length of 2"square solid bar down into it then added another piece of 2.5" tubing to keep it uniform. This is what supports the upside down "T"
The upside down "T": The horizontal edge had a "V" notch cut into it to which I welded an 8" long piece of 3"x3"x1/4" thick angle iron. The upper vertical splitting edge was welded to it & the horizontal flat creating the upside down "T". The angle iron is then butted up to the 2.5" length of tubing which stick up above the fixed wedge which gives it the 4-way/cross look. Then cut a couple 1/2" lengths of the angle iron to go on the backside of the 2.5" tubing. Weld one to the angle iron on the wedge towards the bottom & one at the top. You will have to shorten these small pieces of angle iron so you have a close to the tubing but not a tight fit. I used angle iron instead of 3" tubing on the "T" so if the 2.5" wedge mount should bend any and the 4-way option were to get stuck, you only have to cut a half of inch of angle iron on the bottom retainer, spread it a little & off it will come. Back of 4 way wedge.jpg4 way beside single wedge.jpg
To keep the vertical edges in alignment, I welded 2 small pieces of steel to the underside of the "T" which cradles the lower vertical/fixed wedge. (See 2nd picture)
I have split several cords of wood with this wedge system & am very happy with it. A couple of additional benefits: 1 - The taller wedge cuts the "strings" allowing the rounds to fall apart more consistently. 2 - You can stack up 2-3 smaller rounds & split them at the same time.
   / Log Splitter Wedge ripped off. #14
Scotty can you show us some pictures of the rest of the splitter?
Thanks for the ideas Oliver - the pictures REALLY help.
Picked up some 7018 rods...will get to this job soon, I hope ;)
Panhapp - what pictures would you like?
   / Log Splitter Wedge ripped off. #16
From looking at just the wedge end I am wondering if you might be ahead to replace the beam. How about the cylinder mount and such?
   / Log Splitter Wedge ripped off. #17
Not trying to discourage you but this job isn't for an amateur ,the 70 series rods are IMO best welded with DC current,and a lot of experience to get the penetration you need to without melting thru the thinner beam....anything less than a great job will result in another failure..
Panhapp - the i beam is good and the cylinder mount is solid -
Raw Dodge - No problem. I am not afraid of failing on this - its all part of the learning curve. I will give it my best and if it doesn't hold will buy or build something from Northern or maybe like Oliver made. I have some time as I am splitting next years wood at the moment.
   / Log Splitter Wedge ripped off. #19
I agree...I use 7018 for cover passes, not root passes.
Let me ask for some advice - I have a DC stick machine and I have run about 24 inches of rod so far so take that into consideration.
For a newbie - how would you attack this? I have already ground bevels into both pieces. I have 6011 and 7018 to use. I also have a mig 110 machine with flux core. My plan was to stick weld it in place and to also attach a single brace from the top of the wedge to the i beam much like the existing bolt welded in place but higher up.
I am just looking for some friendly advice on how to attack this. Clearly it does not need to be pretty just functional and if it last another 25 cords that is PERFECT for me. I already plan on doing A LOT of grinding after its welded!
2011 JOHN DEERE 310SJ BACKHOE (A51242)
2011 JOHN DEERE...
Bush Hog Mod. 300 - 14 3 pt Blade (A50514)
Bush Hog Mod. 300...
2018 JOHN DEERE 700K LGP CRAWLER DOZER (A51242)
2018 JOHN DEERE...
2014 CATERPILLAR 277D SKID STEER LOADER (A51222)
2014 CATERPILLAR...
Kubota SVL 95-2s 14009 SKID STEER (A50322)
Kubota SVL 95-2s...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
