Log Splitter - I beam or box beam
   / Log Splitter - I beam or box beam #21
Tubes are excellent for torsional (twist) and axial (column) loading, while W shapes are far less efficient.
On the other hand, W shapes are excellent for major axis (beam) bending, while tubes are far less efficient.
Optimum woult be a rectangular tube with the long side vertical, or a heavy wide flange beam with some side plates on it.
Just some food for thought.
Yooper Dave
Yooper Dave-
Any thoughts on suggested dimensions?
   / Log Splitter - I beam or box beam #23
L3650-
Sorry for the delay. I guess I should pay closer attention to all the posts - so many to choose from at any given time.
Items to keep in mind:
Tubes are usually the most expensive pound for pound.
Can you get a welder at a reasonable cost to weld some side plates to a wide flange beam?
What is your budget?
What can you get readily from your steel fab shop?
How long of a beam are you looking for?
You will need something stout if you want longetivity.
Good Luck
Yooper Dave
Yooper Dave -
I've got some very reasonable prices on material from S&I Metals. I've also been talking to a neighbor who does some work for local farmers.
I had a line on a 5-1/2 inch ram, but that fell through. So now I'm waiting to size based on what I end up with for a ram. Fleet Farm used to offer 5 inch rams, but not right now.
You're in Green Bay, so am I. Small world.
1998 PETERBILT 377 MIDROOF SLEEPER (A58214)
1998 PETERBILT 377...
Zero Turn Mower (A59231)
Zero Turn Mower...
2010 Ford F-550 4x4 Venturo HT40KX 3 Ton Crane Mechanics Truck (A59230)
2010 Ford F-550...
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
International 424 Loader Tractor (A59814)
International 424...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
