log splitter hydrolic fluid question
/ log splitter hydrolic fluid question #1
Easy48827
Eaton Rapids, MI
John Deere L111, craftsman gt3000, Ford NAA Golden Jubilee
Hey all! I've been to your forum quite a few times to get some answers on various projects in the past and want to thank everyone for the valuable info I received.
Now a question I have on my log splitter. Have an older MTD 24 ton and owners manual calls for 7 gallons of either Dextron 11 or nonfoaming 10w oil. Most of what I've read, almost no one uses these in their splitters and mine was built when oil was 60 cents a quart and multi weight oil was not approved for almost anything. One person used Rotella-t 5w30 diesel motor oil which I thought may be a good fit. Any comments would help me make up my mind. thanks!
/ log splitter hydrolic fluid question #2
My BIL picked up an old splitter last summer. He flushed and filled it with atf and it did not work right. Stuttered jerky operation. He found a manual online that spec'd motor oil as the correct fluid. He drained and refilled with 30 weight and it worked great.
For yours, I'd stay close to the published spec.
/ log splitter hydrolic fluid question #3
ATF or 10W-40 motor oil
/ log splitter hydrolic fluid question #4
i agree.. in those apps.. there's probably plenty of oils that would work. even a premium winter utf fluid or R&O light hyd fluid.
Thanks for the answers. For me, the cost is a big consideration plus the "anti-foam" aspect. Can I assume motor oils are all anti-foam? If I do it wrong, 7 gallons is a lot of oil to throw away. Tig- my owners manual says jerky operation is caused by air bubbles in the system. just an FYI.
/ log splitter hydrolic fluid question #6
Just go to Tractor supply and get Hydraulic Fluid-on sale at my store for $27(5 gal.) or wally world.
Yep. Off to TSC- thanks!
/ log splitter hydrolic fluid question #8
tsc has utf on sale for 32$ / 5g and it's better oil than plan hyd oil...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A65053)
2026 DEVELON...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2014 Mercedes Benz CLA 250 Sedan (A61574)
2014 Mercedes Benz...
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A61572)
2018 Takeuchi...
2022 EZ-GO ELITE...
