log splitter hoses
/ log splitter hoses #1
khamill2000
central Kansas
Mahindra 2815 HST
Got a new Speeco splitter from TSC. Was wondering if I could use 1/4 or 3/8 hoses instead of 1/2. When I installed the rear remotes on my tractor I noticed that there was a restrictor (about 1/4) right before the qc's. Would this affect the performance too much? The loader uses all 1/4 lines and seems fine.
/ log splitter hoses #2
We need to know the GPM rating of your pump for a 100% correct answer, but most likely the 3/8" would be OK.
Not sure why you would have a restrictor on your remote-but it could definitely slow the splitter down.
/ log splitter hoses #4
You are powering this from a remote, and will bungee the handle down?
You are right on the edge at 7.8 GPM, according to THIS chart, 3/8" hose is good for up to 7 GPM.
What size hoses feed the remote?
I think you should take that restrictor out, to get maximum flow to your splitter.
No bungee required. Handle stays by itself. The hoses look no larger that 3/8.
I checked them yesterday, The feed hoses are 1/4" I ended up just using 1/2" for the splitter, that way if I ever upgrade tractor, I don't have to change hoses.
/ log splitter hoses #8
The main problem with using the smaller hoses is the heat they will generate. Heat kills hydraulic oils. You did good by going with the next size bigger.
Chris
/ log splitter hoses #9
Ultimately, the restriction will be the QD fittings, so, I'd use what hoses came on it. My splitter came w/1/2" lines...so I bought 1/2 to 1/4 adapters for my QDs. Thought about using the "correct" size hoses, but still would have needed adapters at the valve...more hassle and money for no gain...went with the KISS approach.:D
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
(2) FIFTH WHEEL PLATES (A65643)
(2) FIFTH WHEEL...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
250 gal Livestock Lick Tank (A66408)
250 gal Livestock...
2018 Ford F250 4x4 Ext. Cab Pickup Truck (A64194)
2018 Ford F250 4x4...
