log splitter hoses
/ log splitter hoses #1
khamill2000
central Kansas
Mahindra 2815 HST
Got a new Speeco splitter from TSC. Was wondering if I could use 1/4 or 3/8 hoses instead of 1/2. When I installed the rear remotes on my tractor I noticed that there was a restrictor (about 1/4) right before the qc's. Would this affect the performance too much? The loader uses all 1/4 lines and seems fine.
/ log splitter hoses #2
We need to know the GPM rating of your pump for a 100% correct answer, but most likely the 3/8" would be OK.
Not sure why you would have a restrictor on your remote-but it could definitely slow the splitter down.
/ log splitter hoses #4
You are powering this from a remote, and will bungee the handle down?
You are right on the edge at 7.8 GPM, according to THIS chart, 3/8" hose is good for up to 7 GPM.
What size hoses feed the remote?
I think you should take that restrictor out, to get maximum flow to your splitter.
No bungee required. Handle stays by itself. The hoses look no larger that 3/8.
I checked them yesterday, The feed hoses are 1/4" I ended up just using 1/2" for the splitter, that way if I ever upgrade tractor, I don't have to change hoses.
/ log splitter hoses #8
The main problem with using the smaller hoses is the heat they will generate. Heat kills hydraulic oils. You did good by going with the next size bigger.
Chris
/ log splitter hoses #9
Ultimately, the restriction will be the QD fittings, so, I'd use what hoses came on it. My splitter came w/1/2" lines...so I bought 1/2 to 1/4 adapters for my QDs. Thought about using the "correct" size hoses, but still would have needed adapters at the valve...more hassle and money for no gain...went with the KISS approach.:D
2024 MODASA MH-25 I GENERATOR (A65643)
2024 MODASA MH-25...
MAGNUM LIGHT TOWER (A65643)
MAGNUM LIGHT TOWER...
2001 INTERNATIONAL 4700 4X2 S/A UTILITY BODY TRUCK (A66091)
2001 INTERNATIONAL...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
2016 Ford F-550 Service/Mechanic Truck with Crane, VIN # 1FDUF5GTXGEC76689 (A65563)
2016 Ford F-550...
