Log Splitter Hangs Up Beore Splitting with video
   / Log Splitter Hangs Up Beore Splitting with video #11
A log splitter valve will have a detent return, semi-auto.
Prince makes a valve with two levers that is full auto.
You push two levers in parallel, and the log splitter will extend and at the end of stroke, will retract and go to neutral.
It cost more but will save time.
   / Log Splitter Hangs Up Beore Splitting with video #12
With your MDT splitter go with the Speeco or Energy style valve. The Prince valve has the cylinder ports reversed which will require changing the piping.
Thanks...don't want to have any retro-fitting....
I wanted to check back in case anyone has the same symptoms and wanted to know where I ended up. I ended up buying a $69 Northern Tool valve and it mounted exactly the same as the MTD original. That fixed my problem, so clearly it was the valve, as most in the know already knew. Now the ram moves faster, doesn't pause on every piece of wood building up pressure, and when it does pause on a hard piece, it does so for just a second, not ten. And I don't have to jimmy the lever back and forth. Initially I was concerned because the auto kick-out on the return didn't seem right--took to long to kick-out. But after a few cycles that straightened out and now it works great. Glad I did it, saves me a lot of frustration not to mention time.
2015 JOHN DEERE 5100M TRACTOR (A51243)
2015 JOHN DEERE...
2017 JCB 3CX 15HFCE BACKHOE (A51242)
2017 JCB 3CX...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
(2) ROLLS OF HD CHAIN LINK MESH WIRE (A50460)
(2) ROLLS OF HD...
2015 MACK GU713 DAYCAB (INOPERABLE) (A50854)
2015 MACK GU713...
2020 JLG 1732 16,755lb 4x4 High-Capacity Rough Terrain Telehandler (A49461)
2020 JLG 1732...
