Log Splitter Hangs Up Beore Splitting with video
   / Log Splitter Hangs Up Beore Splitting with video #11
A log splitter valve will have a detent return, semi-auto.
Prince makes a valve with two levers that is full auto.
You push two levers in parallel, and the log splitter will extend and at the end of stroke, will retract and go to neutral.
It cost more but will save time.
   / Log Splitter Hangs Up Beore Splitting with video #12
With your MDT splitter go with the Speeco or Energy style valve. The Prince valve has the cylinder ports reversed which will require changing the piping.
Thanks...don't want to have any retro-fitting....
I wanted to check back in case anyone has the same symptoms and wanted to know where I ended up. I ended up buying a $69 Northern Tool valve and it mounted exactly the same as the MTD original. That fixed my problem, so clearly it was the valve, as most in the know already knew. Now the ram moves faster, doesn't pause on every piece of wood building up pressure, and when it does pause on a hard piece, it does so for just a second, not ten. And I don't have to jimmy the lever back and forth. Initially I was concerned because the auto kick-out on the return didn't seem right--took to long to kick-out. But after a few cycles that straightened out and now it works great. Glad I did it, saves me a lot of frustration not to mention time.
LINDE H80D FORKLIFT (A50854)
LINDE H80D...
2014 VOLVO VHD DAYCAB (INOPERABLE) (A50854)
2014 VOLVO VHD...
2025 GIYI Skid Steer Plate Grabber (A50322)
2025 GIYI Skid...
2021 ALLMAND BROS, INC. NIGHT LITE LIGHT TOWER (A50854)
2021 ALLMAND BROS...
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
1998 CATERPILLAR D5M PIPE LAYER (A50854)
1998 CATERPILLAR...
