log splitter (gpm)
/ log splitter (gpm) #1
mavrk
good morning...my tractor is a DK35 with a creeper,back pto and a belly pto. i`m looking at a log splitter to mount on the 3 point.. i need to know the GPM output. the manual says the main pump puts out 7.8 us gal/min. the specs page that came with it says 12.1 gpm...The log splitter specs says it won`t recomend over 11 gpm.
The splitter is a powerhorse, dual split, 3 point,20 ton and sells for $749.99 at amazon. So,would someone please tell what GPM i have or point me at another good splitter. thank you george
talktogeorge@msn.com
/ log splitter (gpm) #2
I don't think you'll be sorry if your splitter is fast. I'm pretty sure though the 12.1 gpm includes the powersteering pump, and you'll hopefully see something like the 7.8 gpm out of your remote. Check the relief pressure as well of the tractor and the max pressure for the splitter to be safe.
/ log splitter (gpm) #3
Also keep in mind that the pump rating should be the maximum output at the engines working RPM, likely something in the 2400-2600 range.
When I'm running my splitter I run the engine at 1600 or so and the splitter is fast enough and there isn't too much noise coming off the engine. I would hate to have to split wood with the engine wound right out, plus you're going to burn more fuel.
Jason
thank you both for the input...back to the manuals-i found the pump capacity that says MAIN PUMP 7.8 gal and POWER STEERING PUMP 4.7 gal which would give the 12.1+ the max pressure of the splitter is 11GPM. so it looks like i can use that 20 ton splitter.. maybe the 15 ton would be better???? and run the engine at a lower rpm ?? george
/ log splitter (gpm) #5
/ log splitter (gpm) #6
Your splitter will work very well with the tractor flow.
If the splitter is to fast, just reduce the engine rpm.
i appreciate all the info. i ordered my splitter george thanks again
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
KOMATSU PC88MR-11 EXCAVATOR (A64279)
KOMATSU PC88MR-11...
2022 EZ-GO ELITE...
2012 Freightliner FLD120 Ambulance (A64556)
2012 Freightliner...
2020 Ford F-150 4x4 Ext. Cab Pickup Truck (A64194)
2020 Ford F-150...
(2) STAINLESS STEEL HOG FEEDERS (A64278)
(2) STAINLESS...
