Log splitter build
/ Log splitter build
Looking back at the picture of my old one I do have a lot sharper angle. The good old days when I had a machine shop at my disposal, I just torch cut this one and the beetle only went to 45*
/ Log splitter build #82
My wood splitter blade used to be sharp until I got ahold of a piece of wood with about six 1/4 diameter nails in it right in a row. Of course it hit all of them. More pieces in the same tree were had 1/2 bolts in it. Needless to say my wedge looked rough after that. I cleaned it up some with a grinder, but I wasn't that worried about it.
Greatly improved sharpening the wedges
/ Log splitter build #84
I torch cut the edges on my wedges first too. If you look close, you can see a few gouges even after hitting the wedge with a grinder. I have found that a cup type grinding rock on my 7in grinder will cut the metal pretty quick, but it still takes a bit of elbow grease to get it done.
I used 40 grit sanding pads. Rips of off on no time
/ Log splitter build #86
I like those flapper disc also. I try to keep 40,60, 80 grit on hand. They just dont last as long as grinding rocks. I am still using one cup stone that I used to sharpen the edges on my 12way wedge. Those blades are 30in long and a lot of cutting and grinding. I did use the flapper disc to polish the edges once the heavy grinding was done. http://www.northerntool.com/shop/to...ntent=159931&gclid=CJbrt7Ddqs8CFUk2gQodQa4NcA
I would say this splitter is faster than the other one, or maybe I'm just trying to make myself feel good
Longevity is not an issue for me because I get them from work haha
/ Log splitter build #89
I like the trailer. Keeping an eye out for a free one so I can tow it with the tractor & get multiple implements to a job site. Most of my gigs are under a 20 min tractor ride from home, not worth loading & unloading the tractor to haul with the truck.
iDrive TDS-2010H...
2019 Ram 4500 4x4 S/A Dump Truck (A59230)
2019 Ram 4500 4x4...
Patterson water pump (A59230)
Patterson water...
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
Case Titan 3530 (A61307)
Case Titan 3530...
