Buying Advice Log-Splitter & 3-Point Hitch
/ Log-Splitter & 3-Point Hitch #1
OneMarineE5
Stewartstown, PA
JohnDeere 2720
Just saw what appears to be a very nice 22ton splitter at TSC. It's a County Line which must be their brand as it has the TSC name on it as well. This unit costs $699.00.
Anyone have any experience using a splitter in this power range powered by tractor?
/ Log-Splitter & 3-Point Hitch #2
Bought one of these last year and have no real complaints. A big plus is that they are made by SpeeCo of Golden, Colorado. They have a customer service # and will talk you through the setup.
The unit comes with two different valve pistons. You use the one that's right for the type of hydraulic system you have. All instructions are included, but changing the piston takes a little time and patience.
With my JD 2240, it's possible to "auto-disconnect" if you fully extend the shaft when operating, so watch out for that. So far, it has split everything I put on it, even 2-3' diameter stuff that I wrestled up to it while it's in the vertical position.
After using it only on the 3-pt last year, I have left the unit standing on its own rather shaky legs this year. Recommend chaining to the tractor if you use not on the 3-pt.
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
1988 BOMAG BW-213PDH-2 SHEEP FOOT ROLLER (A67714)
1988 BOMAG...
2003 Johnson 50hp 4-Stroke Outboard Boat Motor. (A66738)
2003 Johnson 50hp...
11.2-24 Tires - Set of 4 (A68134)
11.2-24 Tires -...
Lot of 2 ForeRunner 12-16.5N.H.S. Skid Steer Wheels and Tires (A64553)
Lot of 2...
DITCH WITCH 3700 TRENCHER (INOPERABLE) (A67714)
DITCH WITCH 3700...
