Log puller
/ Log puller #1
Egon
Epic Contributor
Nova Scotia, Canada
Came across this picture of a log puller. Also noted it had front forks for lifting.:D
/ Log puller #2
Don't think to much will stop that beast once in 4wd.
/ Log puller #5
That ain't no tractor, and the logs smell funny. 1 MP {moose power}
/ Log puller #8
The front forks only stay on for six months or so and then need to be replaced. :p:p. The good ones have 1500 to 1800 lbs of thrust:p
/ Log puller
[If it breaks down you can eat it/QUOTE]
On that one I'll pass on the eating bit. Them front forks with the branch gathers attached indicate it is long past even consideration for sausage!:D
/ Log puller #11
Where is the 4 wheel drive lever?
You sure you want to know???? _ I do know it can also be activated by gunshot:eek:
/ Log puller #12
they taste good long into the 60 inch range. My uncle got a 66 incher two years ago and the steaks and back strap were great. Hauling it out of the woods did work up a appetite. the "forks" are about 300 pounds with a skull
/ Log puller #13
we measure width of the rack, a 60 inch is 60 inch at its widest point
/ Log puller #16
Good Mornin Egon,
I will take the backstraps anyday ! :D
/ Log puller #17
Ha ha ha. Seen that photo before. It's a great one. Can you imagine that beast coming at you with a load of logs behind. You'd think you'd have gone crazy. :D:D:D
Great pic Egon!
340 GAL WATER TANK (A68842)
340 GAL WATER TANK...
2015 KENWORTH T680 (A67714)
2015 KENWORTH T680...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
2005 INGERSOLL-RAND SD-116F TF  ROLLER (A69167)
2005...
