Log puller
/ Log puller #1
Egon
Epic Contributor
Nova Scotia, Canada
Came across this picture of a log puller. Also noted it had front forks for lifting.:D
/ Log puller #2
Don't think to much will stop that beast once in 4wd.
/ Log puller #5
That ain't no tractor, and the logs smell funny. 1 MP {moose power}
/ Log puller #8
The front forks only stay on for six months or so and then need to be replaced. :p:p. The good ones have 1500 to 1800 lbs of thrust:p
/ Log puller
[If it breaks down you can eat it/QUOTE]
On that one I'll pass on the eating bit. Them front forks with the branch gathers attached indicate it is long past even consideration for sausage!:D
/ Log puller #11
Where is the 4 wheel drive lever?
You sure you want to know???? _ I do know it can also be activated by gunshot:eek:
/ Log puller #12
they taste good long into the 60 inch range. My uncle got a 66 incher two years ago and the steaks and back strap were great. Hauling it out of the woods did work up a appetite. the "forks" are about 300 pounds with a skull
/ Log puller #13
we measure width of the rack, a 60 inch is 60 inch at its widest point
/ Log puller #16
Good Mornin Egon,
I will take the backstraps anyday ! :D
/ Log puller #17
Ha ha ha. Seen that photo before. It's a great one. Can you imagine that beast coming at you with a load of logs behind. You'd think you'd have gone crazy. :D:D:D
Great pic Egon!
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
2009 ALLMAND MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
2023 Ford Explorer SUV (A66738)
2023 Ford Explorer...
2016 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2016 FREIGHTLINER...
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
2011 FOREST RIVER T/A CARGO TRAILER (A67714)
2011 FOREST RIVER...
