LockNLube Easy-Prime Lever Grease Gun?
   / LockNLube Easy-Prime Lever Grease Gun? #1
Sid Post
Platinum Member
TX and OK
Massey 5711D, Kubota L4600, Kubota B2601
It is time for a good grease gun for my tractors and implements. Does anyone have thoughts on the LockNLube Easy-Prime Lever Grease Gun? Is it worth the ~$90 or so it costs these days? Or, is there something better or similar for less money worth considering? I have a $30 Almetite today which is okay but, nothing to get excited about. The Lock'n'lube connector on their grease guns seems like a worthwhile feature. The suction feature with Easy Prime also seems attractive but, I wonder about losing grease in the tube when hot outside and stored vertically or on its side, the old plunger-style grease guns at least kept the mess mainly inside the grease gun.
TIA,
Sid
   / LockNLube Easy-Prime Lever Grease Gun? #2
TIA,
Sid
Lock and lube makes a great grease gun, but I wouldn’t spend $90 on a manual gun. HF typically runs a special: buy a Hercules battery and charger for $99 and get a free tool. One of the free tool options is a Hercules electric grease gun that is fantastic.
   / LockNLube Easy-Prime Lever Grease Gun? #3
I have the foot operated grease gun with the long tip.
Works great
   / LockNLube Easy-Prime Lever Grease Gun? #4
I have a LockNlube grease gun, works great if the fat tip fits on the fitting but it very often doesn’t fit because the tip is to fat
   / LockNLube Easy-Prime Lever Grease Gun? #5
I've had a LocknLube Easy-Prime Grease gun for over a year now and had no problems with it. Works as advertised and does not leak grease out the bottom no matter what position I store it in or use it in. It ships with 6 (if I remember correctly) plastic followers that go into the open end of the grease gun. Those followers seal the bottom perfectly and as you pump grease the follower moves up, following the grease. If I haven't used it in a while it will lose prime but just follow the instructions to get it going again.
   / LockNLube Easy-Prime Lever Grease Gun? #7
Is loading a grease gun that difficult?
Minor airlock sometimes, cured by opening the vent screw.
If you're going through multiple tubes a day but for the couple a month... in the summer.
   / LockNLube Easy-Prime Lever Grease Gun? #8
Well, I bought the LNL coupler only and found out the body was too large in diameter to fit in the recessed openings on my loader so for me, it's worthless. Tried a McNaught as well and it's worthless as well. While it fits, it won't stay coupled so I'm back to the standard diameter adjustable jaw coupler and the LNL and McNaught take up space in the tool box.
   / LockNLube Easy-Prime Lever Grease Gun? #9
+1 for the Lock N Lube connector. I have a battery-powered Milwaukee and it works okay, when the battery dies I'll replace it with a manual grease gun. I can easily buy 3-4 guns for the cost of a battery. If you don't have a lot of greasing to do (e.g., multiple tractors, combines, bulldozers, etc.) I think any ol' gun will get the job done. For my money, the $90 LockNLube is not better (let alone 3X better) than the $30 Alemite.
   / LockNLube Easy-Prime Lever Grease Gun? #10
My biggest mistake was using the rubber hose at the end of the grease gun for everything. Now I have two grease guns, one with the metal tube, the other with the rubber tube. I use the metal tube on 90% of my fittings. It's just a lot easier and faster.
I've thought about trying the lock and lube fitting, but every time I have a fitting that wont take any grease, I've been able to remove it, clean out the hard grease in the threaded area, and install a new fitting with good results.
I've also thought about getting a cordless grease gun. They might be worth the money. I bought several pneumatic grease guns a decade ago, and hated them. They work, or they don't work. Once they stop working, they are pretty much worthless. For me, it seemed to be a repeating pattern, so I gave up on them.
I have three grease guns right now. My favorite is the one I bought off of Amazon. I think it's called Armilite, or something like that. When looking at them on Amazon, I bought the one with the most positive reviews. The others are from Walmart, and Napa. Both of the other two work fine. One has the rubber hose on it, the other has different grease in it.
   / LockNLube Easy-Prime Lever Grease Gun? #11
I have 4 grease guns, two lever, a pistol grip and a mini. One of the lever guns holds corn head (0) grease for filling/adding to gear boxes. The other lever and mini came out of mom & dad's garage when we cleaned the estate, the lever has not been used and I have used the mini a time or two but the cost of cartridges is to high for what it is.
The one I use all the time is an old pistol grip Craftsman that is well near 50 years old, my wife bought it for me not long after we got married. Grease guns are simple tools that with minimal care will not wear out, well other than the hose or coupler. I have a hose on mine, I made a 30" hose from the smallest diameter 2 ply hydraulic hose we had in the shop at least 30 years ago and other than the outer covering coming off the braid it is still going strong. I have little doubt the grease gun and hose will out last me.
I would not pay the high price of the Lock & Lube gun though if I needed one. A good Lincoln or Alemite will last the average user a lifetime.
   / LockNLube Easy-Prime Lever Grease Gun? #12
I've had my Alemite for over 50 years with no problems. Tried a pneumatic one and threw it away after a couple of years. I used a Lincoln cordless for a couple of years and it's been sitting on the shelf unused after constantly getting airlocked.
   / LockNLube Easy-Prime Lever Grease Gun? #13
Nice thing about the Lincoln or Alemite couplers is, the bottom half of the coupler is adjustable for grip. The cheap ones cannot adjust.
   / LockNLube Easy-Prime Lever Grease Gun? #14
If anyone wants the Lock-N-Lube coupler or the McNaught coupler I have, I'll send them to you, you just pay the postage (USPS Flat Rate Priority box) as neither one of them work in my application.
I'll take the lock'n'lube. The other might work too.
added: PM Sent.
2018 Nissan Rogue SUV (A59231)
2018 Nissan Rogue...
JOHN DEERE 6430 PREMIUM TRACTOR (A60430)
JOHN DEERE 6430...
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
2007 JCB 3CX BACKHOE (A60429)
2007 JCB 3CX...
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
