Oil & Fuel Lock N Lube
   / Lock N Lube #2
I have had it for about 6 months, works great for my needs. I only have the one tractor and assorted implements .
   / Lock N Lube #3
Check out Lube Shuttle. It has a zerk lock similar to locknlube also. Works awesome.
   / Lock N Lube #4
great investment . I grease alot of equipment and It saves alot of time
   / Lock N Lube #5
I bought one. Found it cumbersome, messy, bulky and time consuming.
Bought another type, can't remember the name. Less messy, less bulky, still time consuming.
I mailed them both to Murph.
   / Lock N Lube #6
And they both work fantastic thank you Brother Richard!
   / Lock N Lube #7
I got one and put it on my Dewalt grease gun. Both work great. And because it is a lot easier with the electric gun, I tend to use it more.
   / Lock N Lube #8
You're very welcome!!!
Merry Christmas Brother Murph!!! :santahat:
   / Lock N Lube #9
I also use a Dewalt gun.
If you do a lot of greasing and want to do one thing to improve that condition, buy a battery powered gun. :)
   / Lock N Lube #10
I bought both a Lock-N-Lube and Univer-Co. The Univer-Co is nearly the same size as a regular gun end and was supposed to be easier to use. Didn’t turn out that way. Most of the time it was difficult to remove. The Lock-N-Lube can be difficult to remove if a fitting won’t take grease and my Milwaukee electric pumps up to its rated 10,000 psi.
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2015 Top Hat T/A 20 ft. Gooseneck Trailer (A50860)
2015 Top Hat T/A...
5K BLOWOUT PREVENTER (A50854)
5K BLOWOUT...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
