Oil & Fuel Lock N Lube
   / Lock N Lube #21
Yes, and have been using mine for 3-4 years. Wonderful tool
   / Lock N Lube #22
So what is this Lumax LX-1403 I see advertised at the top of the page. Competion?
   / Lock N Lube #25
Because of the price, and never had one my entire life, I almost didn't buy one....Almost being the operative word...
I did end up buying one over a year ago and I've got to tell you this is one slick little device which when mounted to a flexible hose takes all the frustration out of maintenance. In fact, it worked so well I now have three of them!
   / Lock N Lube #26
Right. :thumbsup:
I may have the only lever gun with a 48" hose:
   / Lock N Lube #28
If you use a lever gun a hose becomes advantageous and the LnL is valued.
I haven't used a lever gun for at least 25 years. Don't even have an old one laying around.
Our needs and uses vary a lot here
   / Lock N Lube #29
Yep, needs, uses and preferences are very different.
I prefer the lever gun over the Lincoln, even though it also has a LockNLube :thumbsup::
   / Lock N Lube #30
I can't even fathom why anyone would buy a traditional grease gun over a Lube Shuttle grease gun. They also have a zerk lock fitting that works as well as LnL. I mentioned it earlier in the thread, but it's like it wasn't seen.
Check out this video that TractorTimeWithTim made: New Grease Gun Technology! Greasing The 125R/123E Drive Shaft - YouTube
They have powered guns as well. Little bit more expensive, but well, well, well worth it.
2023 TrailMaster 200EF 4x4 Utility Cart (A55851)
2023 TrailMaster...
4 Cubic Yard Dumpster (A55851)
4 Cubic Yard...
UNUSED RAYTREE REDM32 HYD EXCAVATOR MULCHER (A57193)
UNUSED RAYTREE...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
PAINT ROOM EXHAUST FAN (A54757)
PAINT ROOM EXHAUST...
2019 GEHL RT105 SKID STEER (A52707)
2019 GEHL RT105...
