Oil & Fuel Lock N Lube
/ Lock N Lube #21
Yes, and have been using mine for 3-4 years. Wonderful tool
/ Lock N Lube #22
So what is this Lumax LX-1403 I see advertised at the top of the page. Competion?
/ Lock N Lube #25
Because of the price, and never had one my entire life, I almost didn't buy one....Almost being the operative word...
I did end up buying one over a year ago and I've got to tell you this is one slick little device which when mounted to a flexible hose takes all the frustration out of maintenance. In fact, it worked so well I now have three of them!
/ Lock N Lube #26
Right. :thumbsup:
I may have the only lever gun with a 48" hose:
/ Lock N Lube #28
If you use a lever gun a hose becomes advantageous and the LnL is valued.
I haven't used a lever gun for at least 25 years. Don't even have an old one laying around.
Our needs and uses vary a lot here
/ Lock N Lube #29
Yep, needs, uses and preferences are very different.
I prefer the lever gun over the Lincoln, even though it also has a LockNLube :thumbsup::
/ Lock N Lube #30
I can't even fathom why anyone would buy a traditional grease gun over a Lube Shuttle grease gun. They also have a zerk lock fitting that works as well as LnL. I mentioned it earlier in the thread, but it's like it wasn't seen.
Check out this video that TractorTimeWithTim made: New Grease Gun Technology! Greasing The 125R/123E Drive Shaft - YouTube
They have powered guns as well. Little bit more expensive, but well, well, well worth it.
/ Lock N Lube #31
Lock & Lube also has a G-Gun for those who have a lot of greasing to do, works great!
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A62131)
UNUSED WOLVERINE...
BTI TB 1280XL Hydraulic Rock Hammer (A61166)
BTI TB 1280XL...
8064 (A61166)
8064 (A61166)
Lincoln Electric Ranger Welder (A61166)
Lincoln Electric...
2022 All Aluminum Timpte 514 Trailer Electric Tilt (A63118)
2022 All Aluminum...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
