Tires Loading the tires
   / Loading the tires #1
lunbrjck
I am going to load the tires on the back of my tractor with windshield washer fluid and was wondering if anyone knows how many gallon I will need to do this. The tires are 12 x16.5 industrial
Thanks
   / Loading the tires #2
Around 20 per side, if I remember correctly.
BTI
   / Loading the tires
Thanks BTI think I will get 45 gallon to be on the safe side.
   / Loading the tires #4
If you live where it can freeze, make sure to buy the kind that is designed for freezing weather. There is also a version designed for use only above 32 degrees. It would be quite a ride if you had 3/4 of your tire filled with ice. Talk about being unbalanced............
   / Loading the tires #5
Wouldn't it be cheaper to just use a gallon of radiator fluid and water? I'm saying this assuming only a gallon per tire would be needed.
   / Loading the tires #6
Depends on what temp of freezing you want to attain.
50/50 is protected to -34 if using it in a radiator.
That would be 10 gallon of Anti per side.
But if cut to 25/75 would still be 5 gals per side.
I'd rather leak a little wwf than a little anti.
Personal preference I suppose.
BTI
   / Loading the tires
Howdy filled the R4's on my CK20 last night with ww -20 degree fluid. It took about 40 minutes a tire with having to quit to bleed the air off. Each tire took 16.5 gallon of fluid. Should add about 260 pounds to the rear of the tractor. I used a small drill pump and an adaptor from Gemplers.
   / Loading the tires #8
Being that WW is so light (As in turn to gas easily), has anyone experienced they tire pressure rise in the summer, and dropping when it get s cooler?
   / Loading the tires #9
** nope
   / Loading the tires #10
Do you have a link for the drill pump? Also, what adapter are you speaking of?
I picked up a valve adapter from TS (Tractor Supply Company - Monkey Grip Air Water Adapter Kit) . What else might I need? Can you write up a how to with the tools you used?
Thanks!!
2803 (A50460)
2803 (A50460)
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
2014 STEPHENS CRUDE (A50854)
2014 STEPHENS...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
Horse Hay Feeder (A50515)
Horse Hay Feeder...
Willmar 4300 Wrangler Loader (A52128)
Willmar 4300...
