Loading straw
/ Loading straw #1
D7E
manitoba
Versatile 895 Versatile 876 Ford TW20 Ford TW5 MF 3505 FWA MF 390 FWA Ford 7600 Fiat 766 FWA JD 2030 MF 165 MF 35 Fordson major x 3 CAT 416 b Backhoe Case 580 b backhoe MF
Moving the last few loads of wheat straw yesterday !
/ Loading straw #2
I am just curious, what baler do you use and is the straw from a conventional or rotary. I have friends having trouble with straw from rotary combines and I thought maybe I should suggest the medium square if that is working for you.
Brent
/ Loading straw
IH rotary combines and hesston balers. I also do some with a NH 855 chain round baler if i get orders for round bales , Cant say i've had any trouble ..do have to re set the string pattern on the round baler for rotary straw to move the outer strings in a bit as they have a habit of slipping off the bale if moved a lot .
/ Loading straw #4
I'll have to ask what he uses for string spacing tx.
Brent
SARLO (A64557)
SARLO (A64557)
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63689)
Neckover GL24-2-7K...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A63276)
2017 FORD F-350 XL...
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
2005 Kawasaki STX-12F (A64127)
2005 Kawasaki...
