loader wont raise
/ loader wont raise #1
Tombo
Casco, Maine
none yet
I tried a search on this, but came up nil...
I have a 4110 hydro with a 410 loader. The loader was operating normally, then, as I drove into a pile of gravel, I found I could not raise it. I was able to curl the bucket, dump th eload and back away, but the up/down function is inoperable. I have plenty of hydro oil in it. The backhoe, steering and 3PH rockshafts all seem to be OK. What is wrong with this thing?
Thanks in advance!!!
/ loader wont raise #2
make sure your quick connects are tight. they can look tight but not be all the way in. i am a newbie and discovered this recently.
/ loader wont raise
I doublechecked: even took them off and put them back on to be sure, but nothing. It has down pressure, but no up.
/ loader wont raise #4
I had a similar thing happen to my 410 loader and found that I needed to replace the "guts" on one of the quick connect assemblies. When I explained to the dealer the problem he knew right away what was wrong. Not saying it is your solution but it sure took care of my situation.
/ loader wont raise #5
It definatly sounds like a QC (quick coupler) problem. Try switching the hoses and see if the problem switches also.
/ loader wont raise #6
Yep......double check your quick couplers.......I have had tis problem from time to time and a coupler that came loose was the culprit every time!!!
/ loader wont raise #7
Do you hear the pump whine when you ask for up? Then its probably a bad quick connect
/ loader wont raise
the pump does whine. I will call te dealer tomorrow. Thanks for all of the replies!!!
/ loader wont raise #10
Miller_tractor said:
Change your hydraulic filter
I'm pretty sure if the hydraulic filter was plugged he would have lost more than one function on the loader.
/ loader wont raise #12
The leverage and cylinder size is different.
Has the filter ever been changed?
How many hrs on the machine?
A filter is less than $10.00 and takes 5 minutes to do.:D
When it comes to hydro problems 99% of the time it goes back to the filter.
/ loader wont raise
90 hours and I changed the filter @ 50. The backhoe, steering, bucket dump and hydro all work fine.
I changed 2 out of the 4 quick couplers this week. JD is coming to get it tonight. It is still under warranty and my dealer said he would come to the rescue.
Many thanks,
Tombo
/ loader wont raise #14
I had a simular problem with my 4320 while clearing some land. 1 of my quicck couplers had been bumped and wasn't seated all the way.The way it was acting II really thought I had broke something.But after bleeding down the hydraulic pressure I reseated them all and it worked like a champ
/ loader wont raise #15
/ loader wont raise
The dealer fixed it in my driveway. It was a faulty coupler, just one I hadnt replaced. Isnt that always the way?
2001 Ford F-650 18ft Rollback Truck (A61573)
2001 Ford F-650...
211453 (A62131)
211453 (A62131)
2022 EZ-GO ELITE...
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
John Deere 50 (A60462)
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
