Loader Woes
/ Loader Woes #1
JimR
Elite Member
Central Ma.
Kioti NX4510HST
Last week my loader on my 7275 Cub cadet was not operating like it should. You could hear the pump whining sometimes and the loader would operate really slow. Other times it would work just fine. The oil and filter have only about 50 hours on them. I noticed that the lever on the loader valve was hitting on all four sides of the mounting bracket when in use and thought that me be the problem. I thought there was not enough throw for the loader to work right. The lever holes were worn and the retaining pin for the lever was really grooved out. I welded up the pin and re-machined it. The loader lever got welded up and a new cross hole drilled in it. I also took the valve apart to make sure that there was nothing floating around in there. It was clean except for the back end float area which was full of rusty water. I put this back together and it was working fine for two days. Today I was using the tractor and it is acting up again. It appears to have a restriction in the valve or some other part of the system. One of the hoses goes stiff when using the loader lever in any position except the float position. I also noticed that if I very slowly move the lever to lift the loader it will work just fine most of the time. Then all of a sudden it goes into that same slow mode and the pump starts whining like I'm trying to lift 2000 pounds in a 1100 pound rated loader. Any ideas as to what the problem may be. It was doing this prior to my tearing into the loader valve.
/ Loader Woes #2
From the intermittent performance, sounds like there is some debris in the line, sometimes clogging, sometimes not. Maybe some of that rust got into the system and is affecting the valve opening/closing? Another thing to look for is maybe your relief valve is sticking or the spring is worn out. That would be like you're trying to lift #2000 all the time and hearing that whine. Fluid might be bypassing via the relief valve instead of being diverted to the work ports.
/ Loader Woes #3
Couple of questions: Bear in mind I am not specifically familliar with your hydraulic system, only hydraulics in general.
Have you looked over the suction pipeing between sump and pump inlet?
When the slow action is encountered, does the engine RPM drop significantly like the hydraulic pump is under heavy load?
A pump shouldn't make noise, or should I say it shouldn't make unusual noises. The only time a pump should really make noise is when it is cavitating/trying to pump air, or it is under extreme load. The safety reliefs on the system should prevent it from ever reaching a pressure high enough to make excessive noise(with some exceptions I will note below).
The system is open centered, so the flow is unrestricted and at low pressure/high flow untill you restrict it by sending it to a cylinder(high pressure/low flow performing work). The only thing that should whine is the safety relief valve when it's opening pressure is exceeded by excessive load on the cylinders you sent the fluid to, and it starts flowing fluid to the return port. Most valves supply input flows past the safety which will dump fluid into the return port and back to the resovoir. Typically the main flow goes right thru the valve (power beyond port) to other downstream devices such as a 3PH valve. When a valve is actuated fluid is sent to a cylinder. The fluid comming back on the return working port line from the cylinder also heads to the valve return port and on to the resovoir.
If the engine is loading down severely when this slow loader operation is happening, check for any restrictions in the return line from valve to resovoir. Work can only be performed when the fluid returning from the cylinder being operated has someplace to go. A restriction on the return line to the resovoir would hydraulically overload the system slowing it's operation. Since the valve safety also dumps to this return line, there is no relief for the pump and it screams(and ultimately dies) and puts a heavy load on the engine. Are there quick connects on the supply and return lines to/from the valve to make removing the loader quicker? Is that line you noted that is going rigid when the problem occurs, the return line back to the sump? If so, check the return line connections and plumbing. Also check any filter canisters or hardlines on the return line. Most filters have a bypass valve that keeps a clogged filter from causing this type problem, or exploding from excessive pressure:(
If the engine dosn't load down when this slow operation occurs, the pump may be loosing suction and or sucking in air thru a loose connection, cracked line or bad pump seal/cracked housing. Because of the density difference between air and fluid, it is far easier to draw air in thru a pinhole than to suck fluid along a line. A clogged suction strainer on the suction line would add to this problem.
/ Loader Woes
The rust was only in the end cap where the float detent balls are. I blew the valve out completey with air.
/ Loader Woes
I do have a power beyond loader control valve. There is quick disconnects on my loader. I found the loader piping guide in my manual last night and will try to see which line is going ridgid when the loader goes into slow mode. It is probably the relief valve that is whining and not the pump. Looking at the stiff line would lead me to believe that it is not a cavitation problem. The motor drops at least a 100 rpm's when the loader goes into this slow mode. When the loader valve is in nuetral there is no whine and the lines are very flexible.
/ Loader Woes #6
I also have a question. What does it take to bring it out of this condition? shutting down, dumping, curling, raising, lowering? Also does it always occur with one particular action but not others or can it occurr with any action?
Mike in Warsaw
/ Loader Woes
Mike in Warsaw
Letting go of the loader lever immediately releases the strain on the hydraulics. The operation of the lever in any of the four positions can cause the hydraulics to start to whine. This problem does not occur all the time. Sometimes the loader works just fine. Then out of the blue it will start straining and operating very slowly in all positons. Then it may start working again just fine.
/ Loader Woes #8
I think Ron is right that the obstruction (if that is what it is) is in the return path from the loader valve to the reservoir. There are only two paths with fluid flowing through them when the loader valve is in each of the four positions: the pressure supply line from the pump to the loader valve and the return line from the loader valve to the reservoir. Of those two, only the pressure line has fluid flow both when the loader valve is in neutral and when the loader valve is activated. Therefore, it must not be the pressure line. But the return line has fluid only when the valve is activated, and that is when the flow slows down. And you said that returning the loader valve to neutral stops the problem, which is when the flow that was going through the return line moves through the power beyond line instead.
If, as Ron said, there is a filter in the return path (probably between the return line and the reservoir), it could be the source of the restriction as well. Some return circuits have a diffuser (a screen or pipe with holes in it) where the return circuit discharges into the reservoir to break up the return stream so it doesn't roil the fluid in the reservoir so much and stir up sediment or introduce air. The diffuser could be intermittently plugged, but it would take a pretty large something to do that and I can't figure how it would have gotten into the system.
Finally, the obstruction could in theory be in the return (low pressure) gallery of the loader valve, but it is almost unimaginable that something would be in there after you cleaned the valve.
/ Loader Woes #9
i think youve got a bad hose. It is closing up internally when you ask for fast flow. A failure of the hose inner liner.
larry
/ Loader Woes #10
What's the power beyond hooked up to?
Assuming it's an open center valve there's always fluid going through the valve to the return line to the sump. Unless the power beyond is plumbed to the 3 pt hitch, or something else, then the fluid only goes through the return line when you use a spool in the valve. If you didn't have the power beyond hooked up and the return line was plugging up it would do it whether you were using the valve or not.
If the power beyond is plumbed (tee'd) into the return line then the plug (if it's the return line) is between the valve and the power beyond tee connection.
Monte
/ Loader Woes #11
This is not necessarilly true, only if it was the last valve in the system would you see the high pressure side(power beyond) plumbed to the return, but this is usually accomplished inside the valve with the use of an open center plug.
But he does have a power beyond outlet. A return line restriction also matches his description of heavy load only when a valve lever is operated(requiring a clear return path).
Monte
That would still be a return line problem as I described earlier. Again the connection of the supply line to the return in the last valve in the system is usually accomplished with the appropriate configuration plug (OC plug)in the valve so you only have one line leaving the last valve back to the sump(from the return port). Since he describes the power beyond port being used, I am guessing it feeds another device.
I have seen many times where people get confused about what "Power Beyond" is. "Power Beyond" is nothing more than a high pressure outlet from a valve to feed the high pressure inlet of another valve or device. You could plumb a hundred valves onto a pump in this fashion, pump to first valves inlet port, and the PB outlet to the next valves high pressure inlet. If I place a heavy load on a valve, that high pressure is felt all the way back to the pump. The high pressure passage thru a valve is able to handle the system pressure applied to it by any work being performed by a valve farther downstream. Using power beyond requires another line leaving each valve(return) back to the resovoir so the safety and the fluid returning from a moveing cylinder via the working ports has someplace to go. The return port is supposed to be an outlet to a low restriction path back to the sump. As such it is usually limited in the ammount of pressure it can deal with. Most of my experience is with Prince valves. Many of their valves that I have seen have a 500 PSI pressure limit on the return port. Exceeding this pressure can cause the "O" rings that seal the spools to leak fluid.
/ Loader Woes #12
Not knowing how the OP's system is plumbed, there is the possibility that the PB could be plumbed into the return line IF there isn't anything else downstream. The PB would need to be tee'd into the return line in that case.
True, but I don't know what's downstream on his PB line. He states "Cub Cadet 7275, FEL, MMM, Box Blade, Scaper Blade, wish I had a backhoe for it.", so the PB might be plumbed into the 3 pt hitch, or the return line.
Monte
True. At the same time I think it could be narrowed down to being between the valve and the tee because the only time that section would see pressure is when a spool gets used, IF the PB is tee'd into the return line.
We're on the same page here. I was just bringing up the possibility of the PB being plumbed into the return line with a tee because I've seen reference to this in the operating manuals for at least one valve. I guess it's incase the PB is installed but not plumbed into another device.
Your comment about the pressure limit on the return line is timely too. I remember another thread where someone plumbed the return line from the FEL to a backhoe and split the valve, or something like that. He was having a hard time finding a valve with PB that fit his older tractor. The FEL control valve was in a confined space with some hard lines to it.
Monte
/ Loader Woes #13
If I pull the 3 point lever all the way back to raise postition it will make a whine and my fel works very slowly if any. Apparently there is a stop adjustment on the fell that when adjusted properly will fix this.
/ Loader Woes
My FEL valve does have a PB port and I do believe it goes to the 3 point hitch. I do know that it goes to the hydraulic block on the motor where three hoses connect from the FEL valve. Yesterday I was messing around with the FEL trying to pinpoint some kind of sequence as to when this screws up. I started up the tractor and the loader worked fine for 2 ups and downs and bucket cycles. Then it started the same old routine of sometimes working and sometimes slow motion. The PB hose is not the one going stiff. I found that the PB line comes out of the top of the FEL valve and goes to the hydraulic block with a letter "N". The line going stiff goes from the bottom inside of the FEL valve to the letter "P" on the block. The other line goes from the lower outside of the FEL valve to the letter "T" on the block. According to my service manual these lines are all in the proper place. I believe the "P" line is the pressure line going to the FEL valve. One other thing I noticed is that the hydraulics only scream in the bucket curl up position once the bucket is all the way curled. It makes a high pitched squeal. Holding the lever in the other three position creates no squealing sound. It looks like I will have to pull the FEL valve off again to try and find out what the heck is going on in it. Or as mentioned earlier that I have a line that has seperated inside and the rubber is flapping over causing a blockage. The relief valve is a seperate valve mounted on the loader frame with two seperate hoses running from T fittings off of the loader lines to the pistons for the boom up and boom down. The more I think about this. I don't feel that it is a eperated line as the PB is working fine. If it were a line seperation the PB would be affected also when the loader is in neutral position. Can the spools overtravel in the valve? I did take all the slop out of the control lever.
/ Loader Woes #15
larry
This is what I was thinking too. At low volume it retains its shape and allows flow, but when you put more volume to it it may work and then suddenly and decisively will close off and severely restrict flow. What happens is that the internal liner on the inlet side of a hose tears (usually at a connection) and acts like a one way valve at times. If you can reverse the hose you will solve the problem at least temporarily.:D This is what I was thinking the other day, but wanted the additional information. I would be suspicious of the return hose from the valve. Check it and if you do not see anything and can try reversing it and see if that cures it.
Mike in Warsaw
/ Loader Woes #16
Mike in Warsaw
Yeah, agreed. There was a lot of missing info atthat time, but the superficial symptoms seemed to fit that as a cause. Now, with all considered, it must be the return hose if its a hose problem.
larry
/ Loader Woes
Mike in Warsaw
I understand your thinking on this. But why doesn't it do it when the loader lever is just sitting in neutral? The oil is still flowing through the lines and valve. I can't see any of the other lines getting stiff. Although they are very short before they attach to the loader steel lines. Twice today the loader worked fine for the first time when I started the motor up and used the bucket. The next time I tried to operate it. It was back to the slow mode again. A half hour later the same thing happened. If I restrict the flow to a trickle by only moving the lever a little bit, the loader will go up faster. There is definitely something fishy going on here. If I get a chance I will pull the lines off and try to take a look through them all. Or better yet, reverse all of them. Most of the lines appear to be original. They are 12 years old with 2760 hours on them. I replaced one a few years ago that blew a hole in it.
/ Loader Woes #18
Fluid is not flowing thru the return line when the loader is in neutral. With the valve in neutral, the flow thru the valve is into the input port and out the power beyond port and on to the next device in line(probably the 3PH control valve).
When you operate the lever, you divert fluid that would normally exit thru the power beyond port to one of the working ports for the spool you are operating, and on to one end of a cylinder to make it move. The fluid returning from the other end of that moving cylinder returns thru the other working port for the spool valve you are operating and goes to the RETURN gallery in the valve and exits the valve thru the RETURN PORT. A restriction on the return line leaving the valve return port will cause pressure to build back up the line against the fluid comming from the cylinder you are moveing. This pressure is felt as hydraulic load on the piston face and slows the loader movement, just as lifting a very heavy load would. This also causes the pressure to build on the line supplying the cylinder and all the way back thru the valve inlet port to the pump. When this pressure exceeds the safety pressure, such as when trying to lift too much weight with the loader or when a cylinder reaches it's end point, the safety valve wants to open and dump this excess pressure. Unfortunatly, the safety valve also dumps to the return gallery in the valve and since the return gallery is backing up already, the excess pressure dosn't have any easy place to go. This is a recipe for killing the pump, damaging the valve seals or blowing a line or cylinder body/seal.
You say it moves faster when you use less valve movement. That is because you are only trying to move the load as fast as the fluid returning from the cylinder can exit the return port into the return line from the valve. As soon as you exceed the ammount of fluid that the return port can handle, the back pressure starts to build and the cylinder slows down because of the return line restriction.
Here is a test for you. Remove the return line from the loader valve. Connect up a temporary line running from that return port into a bucket. Start up the tractor, you shouldn't have any flow from that temp return line tillyou start working the loader valve. See how the loader works returning the fluid to the bucket(temp resovoir). You will have to dump this fluid that builds up in the bucket back into the resovoir from time to time to keep from running the resovoir dry. If the loader works without issue, then the blockage is downstream from the valve along your normal return line. SInce the problem appears to be intermittent, a collapsing/decaying rubber hose liner sounds like an excellent suspect.
/ Loader Woes #19
I think the thought here is that when the loader is sitting in neutral the flow through the valve is going out the power beyond line. When you use the loader only then does flow go through the return line. The flow is the output from whatever cylinders are being used, it's neutral pressure as long as there aren't any restrictions.
If you didn't have power beyond the fluid would always be flowing through the valve and out the return line. As someone else said you might be able to reverse the return line end for end and see what happens. Might be a temp fix. Or at least you'll know if that's the problem.
Monte
/ Loader Woes #20
My money is still on a restriction in the valve itself.
Your first post told us that after you took the valve apart to look for anything floating around in it, ... it was clean, except the float detent area. Then it worked good for two days and started acting up again makes me think there is still something in there.
I don't know enough about how the valve is constructed, but it is possible that the spools that control the fluid direction are screwed up or some debris in there. They might work just fine when cracked (feathered) when there is not enough flow to disturb the debris or put a worn area inside the valve into play. But under full stroke some debris is disturbed or the wear pattern comes into play and causes this abnormal behavior. In other words, when you move the valve lever slightly, it is not enough to allow the phantom piece of debris to alter the valve characteristics. But when you move the levers fully, it does.
