loader valve
/ loader valve #1
2640JD
NW Wisconsin
JD 2640
I would like to convert the valve on my JD146 loader to a single handle "monoblock" unit. One handle for up and down and tilt of bucket. Northern tool has a valve for $200. was wondering if its that simple as changing valves? Hydrulic oil comes from tractor resivior rather than rear remotes.
Tim:rolleyes:
/ loader valve #2
Yes, it is just that simple. You have 6 lines connected to your valve now, and so would the new one. But be aware that your older machine has a "closed center" system on it so you will need the proper valve and/or plug.
This valve from the Surplus Center 9-7401 is convertible to closed center, and they sell the plug for $18.95.
/ loader valve #3
Is there a joystick kit available for your valve? The control valve on my loader can be set up as a single stick or twin stick.
Bill
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
2020 CATERPILLAR 289D3 SKID STEER (A65056)
2020 CATERPILLAR...
2011 John Deere 1200H Bunker Rake (A66734)
2011 John Deere...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
Superior Trailer Product 15 Ton Yard Truck Ramp (A66736)
Superior Trailer...
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A68183)
2008 Allmand...
