loader swap
   / loader swap #1
Tony G
Manchester TN
Case 585
I have a woods dual #195 loader that I want to install on a john Deere 2020. The FEL came off my case 585 which has "open center" hydraulics...my john Deere 2020 is "closed center" hydraulics. Will the that be a problem? The FEL has a joystick two spool valve.
   / loader swap
Guess I am confused...(again). My woods loader came off an open center tractor (case 585)...so are you telling me that the joystick valve is matched to that open center hydraulic system and I will have to purchase a another joystick valve designed for a closed center (JD 2020) tractor
   / loader swap #4
What I said was to check and see if your valve can be adapted to a closed center valve, and if yes, then all you need is a PB adapter and plug or a closed center plug.
If your valve is not convertible, then you will need a new valve.
Do you know the brand and model number of the valve?
   / loader swap
I will not be able to check the valve till tomorrow, but; now I understand you although I don't think I will be able to tell wether the valve is convertable or not. Thank you...
   / loader swap #6
If your open center valve has 7 hoses, it has a PB port, and there may be a closed center plug for it or just plug the PB adapter.
   / loader swap
Six hoses ...looks like I'll be buying one of those valves you suggested JJ.
   / loader swap #8
Look more closer and see if there is an unused port. Someone might not have known to use a PB port even if the valve had one. It is usually located through the center of the valve.
Can you show a picture of the side of the valve with the return port?
   / loader swap #9
Tony G
Yes you'll probably need to buy a closed center valve as some of the older open center valves only had 6 openings IE no opening for power beyond.
   / loader swap
I looked yesterday JJ...no extra port. Now fellas, can I use the cheaper valve? My tractor is 10gpm which is top on that valve...is that ok...or do I need to upgrade to the 13gpm?
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
ASSET DESCRIPTIONS & CONDITION (A54313)
ASSET DESCRIPTIONS...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
CATERPILLAR 120 M2 MOTORGRADER (A52705)
CATERPILLAR 120 M2...
2018 Ford Explorer AWD SUV (A55758)
2018 Ford Explorer...
