Loader stress cracks roll call
/ Loader stress cracks roll call #23
CK 30 HST
Purchased 3-25-05
268 hrs
4 - 1/2" cracks at gussets
I also have a slow leak in the front right tire that has to be related. /forums/images/graemlins/smirk.gif
I would also like a toolbox incorporated into the fix on mine. /forums/images/graemlins/smile.gif
/ Loader stress cracks roll call #24
CK 30 HST
Purchased 3-25-05
268 hrs
/ Loader stress cracks roll call #27
CK 20 bought used in December, 2005, with less than 100 hours. Small cracks on all four corners. I love my tractor and working with it up here in the Smoky Mountains. I look forward to a standard fix recommended by Kioti.
Robbie
/ Loader stress cracks roll call #28
Robbie
/ Loader stress cracks roll call #29
ck20---7/04---449 hrs.---cracks in all four corners(1")
/ Loader stress cracks roll call #30
/ Loader stress cracks roll call #31
CK20HST purchased 2004 - 170 hrs. Cracks at 4 corner bolt holes varying in size from 2-3 mm's to all the way to the panel opening. All cracks radiating to the access opening with one cracked both directions.
/ Loader stress cracks roll call #32
/ Loader stress cracks roll call #33
CK30HST --- 06/04 --- 261 --- no cracks yet but keeping an eye on it.
/ Loader stress cracks roll call #34
/ Loader stress cracks roll call #35
CK30HST - new in April 05 - 146 hours with probably 130 hours of hard loader use. Just took the cover off tonight............ has the gussets and cracks at all four corners where the gusset ends. I have pictures, but they are too big. Have to wait for my daughter to change the size. These cracks have been there for a while and I must admit, it is no surprise after following the discussion and knowing how hard I have used this thing, but that's what it's for. Call to the dealer in the morning. /forums/images/graemlins/crazy.gif /forums/images/graemlins/frown.gif
/ Loader stress cracks roll call #36
/ Loader stress cracks roll call #37
I had some time to kill today before some friends showed up for a barbecue so I pulled the cover off.
Ck30------10/04-------196------4 1" cracks
Greg
/ Loader stress cracks roll call #38
It would be nice to know if those having cracks do one or
more of the following:
> run a tooth bar and use it to rip the ground
> pull out stumps with the corner of the bucket, usually using
the curl function
> lift extremely heavy loads with hooks welded to either end
of the bucket. This usually lifts the rear wheels.
I am not saying the loader should not handle this kind of use,
but it would be nice to know if there is a correlation.
Neither of the CK30s I bought in 5-05 are used this way and
neither has cracks at 45 and 212 hours. Both ldrs are out of
warranty and I may add some of my own reinforcement later,
after I evaluate what Kioti does.
I was going to buy a CK20 this week. Maybe I wait on that...
/ Loader stress cracks roll call #39
I use mine for brush clearing so do many of the tasks you outlined. No doubt using the FEL to haul manure would be less stressful and less likely to put torque stresses on the loader.
/ Loader stress cracks roll call #40
No tooth bar, no welded hooks, mostly brush clearing and moving stones/dirt
Greg
2008 BIG TEX DUMP TRAILER (A67714)
2008 BIG TEX DUMP...
2004 Freightliner FL70 Water Truck (A68183)
2004 Freightliner...
Metal Peacock Lawn Art Statue (A66738)
Metal Peacock Lawn...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2019 ALLMAND LIGHT PLANT (A67714)
2019 ALLMAND LIGHT...
2003 Bombardier Evinrude 75 Outboard Boat Motor. (A66738)
2003 Bombardier...
