Loader shudder when lowering.
   / Loader shudder when lowering. #1
gregp
I noticed that when i lower my loader quickly there is a sort of shudder. It does not lower very smoothly. All other aspects are smooth and shudder free. Could there be air or something in the system? If so wouldnt there be shudder when doing other things such as tilting and raising? By the way TC2dDA with 25 hours on it.
   / Loader shudder when lowering. #2
If you are refering to the 12L loader it has a quick and a slow dump feature on it- if you push it over once it will slowly disperse the load. If you push it twice it will quickly dump. At first it may give the appearance of skipping or not running smoothly. hope this helps
   / Loader shudder when lowering. #3
Mine does the same thing and so does the 3pt hitch. I think i read in the owners manual that it does mean that there is air in the system. but I also noticed that it happens more and less at different RPMs. usually the lower the rpm the less stutter. I also am interested in finding the cause/cure /forums/images/graemlins/confused.gif
Volvo ECR235CL (A53317)
Volvo ECR235CL...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A55745)
2015 VANTAGE...
Ryan Walk Behind Aerator (A59228)
Ryan Walk Behind...
15200 (A56857)
15200 (A56857)
Deere 35P (A53317)
Deere 35P (A53317)
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
