dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,758
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
This brings up a question I never have been sure of. Does the FEL relieve pressure from the common port ahead of the work ports? What happens if you have your FEL relief set at 2500 psi but your backhoe relief set at 2000 psi. I have always thought that the FEL work ports would limit at 2500 and the hoe ports would limit at 2000. But if you went the other way around and set your FEL at 2000 and backhoe at 2500, everything would limit at 2000 psi.
Yeah, that's right. Upstream valves with their own relief on a single pump system will need to at the same
or higher setting versus downstream valves that have their own RV.
